How to test radio module
Hello we need to know how to test the radio modules in our laboratory. We have some RB911s that after installing the ROS via the netinstall, the RB seems to work properly, we can make a scan wireless networks but it’s impossibile to register with the AP, so probably the radio module does not work anymore so we would like to test modules in the laboratory. The same thing also happens with some R52Hn, any suggestions would be helpful for us,
cetalfio
This may not be a radio problem rather a networking config problem. If network is visible but cant connect indicates a config problem usually if the network chip/card hasnt overheated.
Thanks SystemErrorMessage, but we have more than 500 MT devices in production enviroment and this problem is not a setting error but it would seem a lack of radio modules, in some cases it appears to the first use of a R52Hn or RB911.
cetalfio
You could try logging and see if any connection attempt was made. If there was no sign than it could be the module was faulty. Could be the firmware,
