Can I unlock frequency for my sektor RBD22UGS-5HPacD2HnD-15S
to 2,4 ghz range 2312-2497, I can use all freq range on 5 ghz , but on 2,4 ghz NOT , please help
I can use all freq range on old devices like lhg 2,4 sxt sq 2,4
This is frod ???
What is extra channel?
RouterOS extra channel allows you to use extended frequency range from 2312 - 2497 MHz | on almost every Atheros chipset, which allows uninterruptedly data transmission if more signals are available. Get ExtraChanell here.
mikrotik-routeros.net
Depends on regulations (which depends on country code), can you check:
/interface wireless info allowed-channels
https://help.mikrotik.com/docs/display/ROS/Wireless+Interface
Only on north corea are allowed 2,3GHz (same channles name but 100MHz less) and forbidden 2,4GHz,
on all other civil part of the word are allowed only from 2,4GHz to 2,5GHz, and each country have own rule, based on ITU regulation.
https://www.itu.int/net/ITU-R/terrestrial/faq/index.html#g013
Some country sell licenses for use lower and upper parts of 2,4GHz. (out of the classics 1-13 + 14 channels)
