Searched far and wide. mikrotik documentation is lacking.
For example in terminal I want to edit the IP pool ranges.
edit
terminal number: 0
value-name: ranges
The terminal gets a cursor under but nothing can be done with it, i.e., it takes no input from keyboard. The only thing is to escape to root without completing the task of changing the IP pool ranges.
The ethernet itf on your computer does need a working ip config, strange but true, but winbox itself can work on MAC level without a functioning ip config on router.
Provided there is no firewall blocking you. For that reason most foresee one physical port not tied to the bridge as entry.
You might be better off using winbox in these early phases of your learning process.
And there is always the option of Safe Mode. Very helpful when you goof things up.
I’m not really sure what “edit” command does, I never used it. In ROS 6.49.7 (and ROS 7.7) it doesn’t even have short description shown:
[user@mikrotik] /ip pool> edit
.. -- go up to ip
add -- Create a new item
comment -- Set comment for items
edit --
export -- Print or save an export script that can be used to restore configuration
find -- Find items by value
get -- Gets value of item\'s property
print -- Print values of item properties
remove -- Remove item
set -- Change item properties
used -- Used pools
However, using set command does the trick for me:
/ip pool set 0 ranges=192.168.3.100-192.168.3.150
Note that using index numbers (“0” in example above) only works after using print command … indices are not constant properties, they are created by print command and can be used until next print command is executed (even in a different configuration tree branch). So if one wants to execute command above without first executing print command, the correct command would be like this:
/ip pool set [ find where name=pool0 ] ranges=192.168.3.100-192.168.3.150
Adapt the where part of find to match setting that needs to be updated … and make sure it doesn’t match any other setting which has to remain unchanged. It is fine to create “find …” construct so that it matches multiple settings … if all of settings need to be changed in exactly the same way.
Perfect. Basically, instead of editing a property the same property is (re)set/rewritten.
I should have tried that in the first place but I am stubborn. It might be that edit is superseded by set altogether. Wondering why not remove it completely from ROS.
Could be that edit is supposed to work like set, but without first (manually) checking old contents … and interactively so. I most likely won’t even try to find out about it
Don’t forget about “unset” command … sometimes setting of certain property is undone by setting it to empty value … but sometimes empty value is not the same as not being set at all. So if a property is set and one wants to completely remove it from configuration, the “unset” command is the one.
Unset? from 2007 i never used that command or remember that exist…
Usually I use **!**field to “unset” the field on set with other things.
Like
/ip route> unset 1 routing-mark
# is the same as
/ip route> set 1 !routing-mark
# but on set lines I can do more operations at once, if is needed:
/ip route> set 1 !routing-mark gateway=6.9.8.7
“unset” do not cover all fields or all menu covered by set.
“set” do it.
Well, I've never thought of using set !. It seems non-intuitive to me, to me "set not something" is different than "unset something". The same way as "set something to empty" is different than "unset something".
Anyway, I'm glad you have your own ways which work for you
Can you give an example where "unset " doesn't work while "set !" does? This really intrigues me.
It’s just more comfortable like in the third example to do more things together…
¯_(ツ)_/¯
Every day I discover or invent something new on the forum, we never stop learning
Well, the example above is one of those where setting to empty value does the trick, hence no unset command. And setting !comment doesn’t do the trick either. I’d really like to see the example where setting property to empty value isn’t the same as unsetting it … and that it is not possible to unset it while set ! works.
Other than that … where unset works, it’s not “set unset ” … it’s “unset ”.
It seems that unset is only available in menus where items have optional parameters. In IP address, only optional parameter is comment. Any other missing and configuration item doesn’t make any sense. Other configuration items (like firewall filter) have many properties and not all have to be present. Further more, empty value of some properties make perfect sense (as matcher) and treating property with empty calue same as not set property would be wrong. In those configuration parts “unset” exists and makes sense. And I guess (not sure I want to try) in those also “set !” works.
Well, I tried in /ip firewall filter … one can not remove comment (i.e. field where empty value is as good as not set) with either of constructs, only setting with empty value does. But for optional property (I tried with in-interface) both ways (unset X in-interface … and … set X !in-interface) worked the same.
So I guess we’ll continue to use the way we’re already accustomed to.
BTW, where did you learn “your” way? I never noticed it in any of official documents and/or examples. unset is documented (at least in tge self-documenting way in CLI).
