Ok i have an adsl 4 meg line as my main internet conenction.
The mikrotik dials a PPPoE to get the internet. Now i want to install a back up internet source (not adsl line)
The back up source is a wireless connection to annother network.
So if the adsl line goes down it must switch its traffic and route it via the other network. And if possible it must email me informing me the adsl line is down?
So my thoughts are that we are going to ping the main gateway and if that fails it mus then switch. but im not sure what to do with the masquerading if the backup line is just a normal tcp/ip network?
is there maybe a wiki or tutorial that can help me set this up?
You just masquerade on both interfaces to the interface IP addresses. Traffic leaving through the main link get source NAT’d to the IP address on that main link, traffic leaving through the backup link get source NAT’d to the IP address on the backup link.
To get emailed on failure the easiest thing is to implement a netwatch script that also pings the main link’s gateway and emails you on host down and up. Make sure you implement a firewall rule that blocks ICMP towards that main gateway from going out the backup link so that the router can only ping the main gateway through the main link.
And does usermanager count all traffic? local and internet? and it will count internet regardless of which link its using.
And with all the internet firewall rules, like remotedesktop , webserver etc will they all still apply on both links.
Or instead of it emailing me. would it not be easier to maybe set it up to do what the hotspot does.
And if its using the backup link then every now and then i will direct you to a html page (that you have uploaded) saying the backup link is being used.???
And how can i totally isolate my system from that backup link . cause the lan wire goes to a Nanostation 2 set as a router which then goes to the IT guys shop which has internet, but if u know the ipaddresses you can acces info on my network.
How can i make it so that just ineternet goes in and out, and so the computers on my network dont find computers on his network??
What I’ve done was to add default routes for both my PPPoE and failsafe Internet connections, with the PPPoE one’s distance set to 1 and the failsafe one’s distance set to 2. I’ve also enabled the option on the PPPoE interface to ping the gateway to check if the Internet connection is active. Unfortunately that isn’t always reliable, since the Internet problem might sometimes occur further upstream than the first gateway, here in South Africa where I live.
eg. here’s a printout of my default routes
0 ;;; Default WAN connection via PPPoE
dst-address=0.0.0.0/0 gateway=PPPoE-WAN interface=PPPoE-WAN
check-gateway=ping gateway-state=reachable distance=1 scope=30
target-scope=10
1 ;;; Failover WAN connection via wire
dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=2 scope=30
target-scope=10
Now my problem is, for arguments sake say i pull out ether1 (main line) cable and then i onlyplug in ether2(2ndary line) my router does not work? The computers dont have internet.
now i am thinking its because its not a PPPoE link, its jsut a normal lan cable to the nextdoor companies network router. ( just for backup internet)
Do i have to add anything because its just acting as a normal router?
You probably have to enable NAT (Masquerading) on the ether2 interface, otherwise only your router would have Internet access on the failover connection.
For a start, see if you can ping network hosts like www.take2.co.za via your ether2, using the ping tool on the router. If that works, then disable pull out the cable of ether1 and see if you can ping that same host without specifying ether2 as the ping interface.
If those worked, then you can go and try to ping from a PC behind the router.
I’ll host the DNS server on the MikroTik too and then let DHCP assign your router’s IP address for the clients to use as their DNS server.
Then in your DNS settings, you can setup a primary and secondary DNS server.
I don’t have any experience with DNS failover, so someone else should perhaps give recommendations here.
Yea, I thought of that. but i would ideally want the dns server to be on my RB.
But its cool i think i got it allworking now.
Well the internet works on each i have not tested if it automaticaly switches over yet?
Where does it ping to? cause if its the next thing wont that be your ADSL modem?
Also just a question.
In stead of wrighting a script for the RB to email me when the line goes down would it not be possible to accasionaly pop up a webpage saying mane line is down you are currently working on the backup line, please phone xxxxxxx to report this.
So you can use a simelar technique to how hot spot redirects you to its page? or just the advertising part of hot spot?
