Howto Install Web-Proxy Package
Hi i have Mikrotik Installed in system version 4.4 i want to install web-proxy package in my system i intalled it about a year before at that time i havent install proxy coz i didn't need back then now i need it so how shud i install it from within that system
i check my system packages
OUTPUT
[s@s] > /system package print
Flags: X - disabled
NAME VERSION SCHEDULED
0 system 4.4
1 X ipv6 4.4
2 ups 4.4
3 synchronous 4.4
4 routerboard 4.4
5 wireless 4.4
6 hotspot 4.4
7 dhcp 4.4
8 mpls 4.4
9 routing 4.4
10 ppp 4.4
11 security 4.4
12 routeros-x86 4.4
13 advanced-tools 4.4
need some advice
Regard's
Sarbaazi
Download the proxy package from mikrotik.com, copy it to the root folder of the file system, and reboot. Versions have to match. If you cannot find a proxy package for your version consider upgrading everything to the latest 4.x at the same time. To copy files you can use FTP or SFTP depending on your router configuration, or just drag them into the File view of winbox.
i dont see for web-proxy for my mk4.4
thanks for ur support.
Regard’s
Sarbaazi
Probably not. The official download site only has the latest packages. So, like I said, upgrade everything to 4.17 and also install the 4.17 proxy package. That is, more or less, your only choice unless you still have the 4.4 package from when you originally downloaded it.
