are mikrotik 3.x work on HP Proliant DL 360 G5 ???
I think will work but I think you will have limints in interface. Hp comes only with two Ethernet
all our core routers use only one ethernet - works with upto 700 mbps on ~16 vlan interfaces =)
yes it works perfectly on proliant D360 G5!!
How do you install ???
please for help …
what’s problem?..
mikrotik support only IDE / SATA
how to install …
It seems this Proliant has only SCSI interfaces. http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/15351-15351-3328412-241644-241475-1121486.html
Wait! http://h18000.www1.hp.com/products/quickspecs/12476_na/12476_na.pdf They say it has SATA ! Todor please try with SATA!
sorry
to read HP Proliant DL360 G3
USB drives works almost everywhere
So he just plugs in a USB thumbdrive and uses a CD to install on it ? How does the USB procedure go?
I mean, not ide/sata, but usb =)
all our core routers works on USB Flash Drives =)
