is there an http web proxy log ?
if so where is it at?
‘/log print’, if there are not proxy logs.
Set ‘syste logging add topic=web-proxy action=’, and specify required action.
You can send logs to remote server, to store them on disk, memory.
ok great …
i can see a log however where is the file its writing the file to?
i loaded up the ftp client and logged into the server but i dont see any log file to download.
I recommend you to redirect logs to the remote server.
Redirect logs to the remote server, ‘system logging’.
in /system logging Actions → Remote → Remote address what IP should i put in?
i put in the server ip address and port 514 then in the log downloader i addedd the ip howver it keeps saying error
cylent, install log downloader on your PC (for Win), and specify this PC remote address as the remote server address.
Specifty ‘action=remote’ for logs, that you want to redirect to syslog server.
i did what you said. it now says “down” however the folder i selected is empty. no files
heres pictures:
whats wrong?
can you actually ping from the router to that log downloader pc ? and the other way?
Is this address 192.168.x.x (private) accessible from your router ?
argh, Normis replied first ![]()
you’re right. 199 is given to the pc from the dhcp_server and times out when i ping it from the server.
i have another ip, 101, given to me from hotspot and that one responds to ping
how can i make it only one ip? why two?
i think your configuration might be messed up. what two addresses you mean now?
ok. fist in routeros i have a dhcp server enabled.
[admin@MikroTik] ip dhcp-server> network
[admin@MikroTik] ip dhcp-server network> print
# ADDRESS GATEWAY DNS-SERVER WINS-SERVER DOMAIN
0 192.168.0.0/24 192.168.0.1 192.168.0.1
[admin@MikroTik] ip pool> print
# NAME RANGES
0 dhcp_pool1 192.168.0.100-192.168.0.200
this is giving my pc an ip of 192.168.0.199
now comes hotspot.
i have a server setup with the address pool selected: NONE.
Now since my pc is connected to a switch connected to the router i am getting an ip from the dhcp server of 192.168.0.199
as soon as i log into hotspot i am getting another ip, 192.168.0.101 or whatever
i give up
please, go to the singapore training, it will be very very useful ![]()
why are you using the same range in hotspot and in dhcp, and why do you have two systems assigning dynamic addresses to one pc ? this is not normal
i dont know why this unusual for you.
when you setup a new hotspot server it’ll ask you what dhcp pool do you want to use. i merely picked the same pool i have. i can create a new one …
goto winbox, click IP, click Hotspot, click on the SERVERS tab, click on the RED PLUS sign
do you see where it says: ADDRESS POOL? ya. well i have it at none right now
Look at the HOTSPOT DEBUG in this Log.
I want to stop hotspot from giving out another IP. the dhcp server already gave an IP:
