Huawei HSDPA Modem on RB 433UAH problem
i succesfully config an Huawei HSDPA modem on RB 433UAH. But after /system shutdown the routerboard and then start it again, why the usb port status become red? it will going normal again when i /system reboot the router.
is there any way to make it run perfect on 1st boot?
please make the suport output file when you see this problem and send it to support@mikrotik.com
I have seen “movement” of USB devices…
IE Add a drive and USB ports “Move”…
Has caused issues with 3g Devices and Stores going invallid…
May be related..
could you give us more detailed info about this?
bump, there is no further issue about this? suppout file already send since 27 Mei
