Hello, I have a problem, you see I have groups of computers that transmit information let’s say to the center of the network through VPN site to site, I am using L2tp/ipsec, now my problem is that I am needing that the computers that are far from the central house can access the company’s domain, this domain controller is Microsoft and the difficulty I have is that the remote computers cannot access the domain controller since it is not seeing the DNS.
How do I have the DNS?, locally my mikrotik (outside the central house) enters the ips by dhcp being the same the DNS server, this DNS server points to the IPs of my Domain controller first and last I configure any service provider DNS in case the VPN goes down the computers can continue browsing, despite this it seems that it does not make DNS queries to the central house but prefers to do it let’s say 1.1.1.1, for now I have no choice but to tell DHCP to my computers that their DNS server (of the domain) is for example 192.168.1.120 and secondary 1.1.1.1, in this way if they enter the VPN. I don’t understand why if I tell the DNS server that your provider is the domain controllers that are reached by the VPN, it doesn’t send the search, I’ve seen in the cache that it seems to try but the addresses come as 0.0. 0.0 plus the name of the domain controller, but it doesn’t always happen sometimes and it doesn’t even seem to take that into account. If I force the DNS server to only see the domain controller that of course has the role configured if it works but intermittently.
When I create the VPN configuration in the profile tab I configure that the dns server is my domain controller but it seems that this does not help either.
Can you help me with this problem?
Do you are just having DNS issues?
Setup a local recursive DNS server at the remote sites that forwards (or as a slave) the internal domain to the DNS server at the ‘main office’ and all other requests to the DNS server of your choice.
Then point all local hosts to use this DNS server.
It is possible to set static DNS entries on remote routers, like this
https://askto.pro/question/setting-up-a-redirect-in-mikrotik
To avoid problems if one of AD DNS servers goes offline, use script to check servers availability and to disable or enable corresponding entry in static DNS table, and run it periodically with scheduler (in my routers this script runs every minute). Something like this (text in russian but only code matters)
https://habr.com/ru/post/505064/comments/#comment_22701754
Thanks for your answer!, i have that configuration on my topology, but, my DNS server on remotes sites prefers the other DNS server and no take information from my principal DNS server, if i see in DNS cache i can read the names consulted in the DNS cache but the ip address returns as 0.0.0.0 example: domain.local / 0.0.0.0 it is as if it queried but did not resolve the IP address
Thanks for your help, this is my second choice.
Then then fix/correct your DNS server config.
Hi, i fix the problem,
From the server side i put my DNS server (from Domain Controller): Open the tap “profile” in PPP configuration then put in “general” tap the DNS server from your Domain Controller ().
At the other side open PPP → INTERFACE and in the L2TP/IPSEC → Dial Out configuration you must to use “USE PEER DNS” by setting on “yes”, whe you make this setting in the IP → DNS SETTINGS appear on “dynamic Server” the IP that you had configuredg ().
Finally yo can put other DNS SERVER in thsi way if you loss your VPN conection you wil be able to use them.
Bye.
