Reflection occurs when your station receiving its AP signal from more than 1 line !!!
when your Fresnel zone is not really clear you AP signal reflects from near obstacles to your client , then your link could be very unstable , sometimes you get 100 Mbps(feeding from real signal) suddenly drop to 10 Mbps(station feeding from reflected signal).
** Fresnel zone is not Line of Sight , may be you have complete LOS but your Fresnel zone is not really clear.
Reflections are generally a indoor issue rather than signal reception issue outdoors?
There is several easily identifiable items outdoor which can cause reflections such as a nearby metal building or perhaps the worst case is where a link is over the sea and tides cause havoc?
1434Mbps / 8 bits = About 180 MBytes, tomorrow will test with a Gigabit ethernet port computer and try to make a test with iperf… today make a iperf test but two sides PCs are connected through a wifi router and max speed are 3 Mbytes. The real test will be done tomorrow.
Hi, I tried with all rates fixed but bad results, and the results of the picture (about 1500 Mbps) is with card-rates config and lowest dbm (-30)… the signal still in -49db
Mikrotik reports maximum performace at 990Mbps, your results are almost 50% better: http://routerboard.com/RB922UAGS-5HPacT-NM
IMHO WiFi connection should be slower than ethernet one so 1,4Gbps on WiFi is quite strange. How do you want to “feed” WiFi with “so slow” 1Gb ethernet port ?
Are you aware of “Lost packet count” ? Isn’t it too high ? If you loose e.g. 50% of packets then the connection speed seems to be acceptable as real one is at 700Mbps.
you need 300 or 500 MBps not Mbps ?!!
your current link is perfect man , i don’t think so there is a radio which carry 500 MBps !! it’s too much,what you are gonna do wit such a crazy speed ? even a link could support that speed , what device are you using to use that amount of Data ??
what is sender or receiver HDD could read/write 300 MBps ?!!!
even a Lan cable carry 1000 Mbps , network speed measuring standard is bps not Bps
Edit : for a real test use tcp not upd and use random data , if not satisfied on tcp use 2 independent link and setup an OSPF to achieving full duplex
