Hello everybody
I’m studding Layer 7 with MKT, becuase is something WONDERFULL. I ask it in the MUM of Argentina, and they say me A GOOD QUESTION and nothing more. And now appears!!!
But I’ve some problems… ![]()
I insert in /ip firewall layer7-protocol the instructions that are in http://www.mikrotik.com/download/l7-protos.rsc. Then I create this 4 rules in mangle:
0 ;;; HTTP Layer 7
chain=prerouting action=mark-connection new-connection-mark=HTTP_CON passthrough=yes layer7-protocol=http
1 chain=prerouting action=mark-packet new-packet-mark=HTTP passthrough=no connection-mark=HTTP_CON
2 ;;; RESTO
chain=prerouting action=mark-connection new-connection-mark=RESTO_CON passthrough=yes
3 chain=prerouting action=mark-packet new-packet-mark=RESTO passthrough=no connection-mark=RESTO_CON
Finally I open a browser and start use it, and the only marks that appears un CONNECTIOS are “RESTO_CON”, none marks of “HTTP_CON”. Look this is a print of Connections:
17 SA protocol=tcp src-address=10.10.1.253:51260 dst-address=200.43.15.16:80 reply-src-address=10.10.200.1:3128 reply-dst-address=10.10.1.253:51260
tcp-state=96 timeout=5s connection-mark=“RESTO_CON” p2p=none
18 SA protocol=tcp src-address=xxx.xxx.xxx.xxx:43112 dst-address=200.43.15.16:80 reply-src-address=200.43.15.16:80 reply-dst-address=xxx.xxx.xxx.xxx:43112
tcp-state=232 timeout=5s connection-mark=“RESTO_CON” p2p=none
19 SA protocol=tcp src-address=10.10.1.253:51261 dst-address=200.43.15.16:80 reply-src-address=10.10.200.1:3128 reply-dst-address=10.10.1.253:51261
tcp-state=none timeout=4s connection-mark=“RESTO_CON” p2p=none
20 SA protocol=tcp src-address=10.10.1.253:51262 dst-address=200.43.15.16:80 reply-src-address=10.10.200.1:3128 reply-dst-address=10.10.1.253:51262
tcp-state=232 timeout=4s connection-mark=“RESTO_CON” p2p=none
21 SA protocol=tcp src-address=xxx.xxx.xxx.xxx:43113 dst-address=200.43.15.16:80 reply-src-address=200.43.15.16:80 reply-dst-address=xxx.xxx.xxx.xxx:43113
tcp-state=none timeout=5s connection-mark=“RESTO_CON” p2p=none
22 SA protocol=tcp src-address=xxx.xxx.xxx.xxx:43114 dst-address=200.43.15.16:80 reply-src-address=200.43.15.16:80 reply-dst-address=xxx.xxx.xxx.xxx:43114
tcp-state=172 timeout=5s connection-mark=“RESTO_CON” p2p=none
23 SA protocol=tcp src-address=10.10.1.253:51263 dst-address=200.43.15.16:80 reply-src-address=10.10.200.1:3128 reply-dst-address=10.10.1.253:51263
tcp-state=225 timeout=4s connection-mark=“RESTO_CON” p2p=none
As you can see the IP 200.43.15.16 is working in port 80, so it is HTTP!!!
I’m using a HOTSPOT Server to try it, but I think that it doesn’t depends in what type of server I’m using.
Somebody could tell my what I’m doing bad?
Thank you very much
Rafael Loré
