i can't ping wan interface from LAN
hello friends
please i need help, i have a mikroutik hap ac2, i had plug it to an ISP modem that give to the WAN interface a DHCP address 192.168.1.25…
the probleme, i can’t ping from my lan this address.
the config line are :
 ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.88.1/24    192.168.88.0    ether2
 1   xx.xx.xx.xx/25     xx.xx.xx.xx     ether5
 2 D 192.168.1.25/24    192.168.1.0     ether1
and also for ip route :
ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 ADS  0.0.0.0/0                          192.168.1.1               1
 1 ADC  xx.xx.xx.xx/25     xx.xx.xx.xx     bridge                    0
 2 ADC  192.168.1.0/24     192.168.1.25    ether1                    0
 3 A S  192.168.1.1/32     0.0.0.0         ether1                    1
 4 ADC  192.168.88.0/24    192.168.88.1    bridge                    0
and for nat firewall :
ip firewall nat print
 0    chain=srcnat action=accept src-address=xx.xx.xx.xx/25 dst-address=xx.xx.xx.xx/16 log=no log-prefix=""
 1    chain=srcnat action=src-nat to-addresses=xx.xx.xx.xx/25 dst-address=xx.xx.xx.xx/16
 2 X  chain=srcnat action=src-nat to-addresses=xx.xx.xx.xx/16 dst-address=xx.xx.xx.xx/25
 3    chain=srcnat action=masquerade log=no log-prefix=""
 4    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix="" ipsec-policy=out,none
and for firewall rules :
 ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    chain=input action=accept protocol=udp dst-port=500 log=no log-prefix=""
 2    chain=output action=accept protocol=udp dst-port=500 log=no log-prefix=""
 3    chain=input action=accept protocol=udp dst-port=4500 log=no log-prefix=""
 4    chain=output action=accept protocol=udp dst-port=4500 log=no log-prefix=""
 5    chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
 6    chain=output action=accept protocol=ipsec-esp log=no log-prefix=""
 7    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked log=no log-prefix=""
 8    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 9    ;;; defconf: accept ICMP
      chain=input action=accept protocol=icmp
10    ;;; defconf: accept to local loopback (for CAPsMAN)
      chain=input action=accept dst-address=127.0.0.1
11    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
12    ;;; defconf: accept in ipsec policy
      chain=forward action=accept log=no log-prefix="" ipsec-policy=in,ipsec
13    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
14    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection connection-state=established,related
15    ;;; defconf: accept established,related, untracked
      chain=forward action=accept connection-state=established,related,untracked
16    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
17    ;;; defconf: drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
thanks for advance for your help
What LAN?
The lan of ISP modem?
You must convert the hAP ac^2 from router to plain switch + access point, because already your router do NAT?
What is for, and where it come the censored IP on ether5?
do not use print, are useless,
use export instead
thanks for your reply, i use it as a router for an IPSEC tunnel. and i need internet for the LAN also., i had shared a topic about my probleme with the tunnel and i think is because i can't ping the " either1 interface"
the link for the other topic is : https://forum.mikrotik.com/viewtopic.php?f=13&t=177371
the export configuration is :
export
# aug/06/2021 12:05:22 by RouterOS 6.47.10
# software id =
# model = RBD52G-5HacD2HnD
# serial number =
add admin-mac=ZZ.ZZ.ZZ.ZZ.ZZ to-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge ssid=MikroTik-77D1EA wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-77D1EB wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
/ip ipsec mode-config
set [ find default=yes ] use-responder-dns=no
/ip ipsec profile
add dh-group=modp1024 dpd-interval=5s dpd-maximum-failures=100 enc-algorithm=aes-256,aes-128 lifetime=6h name=\
    IKE_Crypto
/ip ipsec peer
add address=P.P.P.P/32 exchange-mode=aggressive name=OURPEER passive=yes profile=IKE_Crypto
/ip ipsec proposal
add enc-algorithms=aes-128-cbc lifetime=1h name=IPSec_Crypto
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=AA.AA.AA.AA/25 interface=ether5 network=AA.AA.AA.AB
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=output dst-port=500 protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=output dst-port=4500 protocol=udp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=output protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=accept chain=srcnat dst-address=RR.RR.RR.RR/16 src-address=AA.AA.AA.AB/25
add action=src-nat chain=srcnat dst-address=RR.RR.RR.RR/16 to-addresses=AA.AA.AA.AB/25
add action=src-nat chain=srcnat disabled=yes dst-address=AA.AA.AA.AB/25 to-addresses=RR.RR.RR.RR/16
/ip ipsec identity
add my-id=user-fqdn:admin@contact.com peer=OURPEER secret=password
/ip ipsec policy
add dst-address=RR.RR.RR.RR/16 peer=OURPEER proposal=IPSec_Crypto src-address=AA.AA.AA.AB/25 tunnel=yes
set 1 disabled=yes
/ip ipsec settings
set accounting=no
add distance=1 dst-address=192.168.1.1/32 gateway=ether1 pref-src=0.0.0.0
/system clock
set time-zone-name=Europe/Paris
/system identity
set name=OURPEER
/tool mac-server
/tool mac-server mac-winbox
thanks
I’m reading, meanwhile the IP and all other things related to the interfaces on the bridge, must be put on bridge!!!
the admin-mac=ZZ.ZZ.ZZ.ZZ.ZZ of the bridge must be equal to the ether2 (original) mac address
yes, my IP interfaces :
export
# software id =
# serial number =
/interface wireless
/ip hotspot profile
/ip ipsec profile
    IKE_Crypto
/ip ipsec peer
add address=80.14.XX.XX/32 exchange-mode=aggressive name=OURPEER passive=yes profile=IKE_Crypto
/ip ipsec proposal
add address=10.10.10.10/25 interface=ether5 network=10.10.10.9
/ip dhcp-client
/ip dns static
add action=accept chain=srcnat dst-address=10.14.10.10/16 src-address=10.10.10.9/25
add action=src-nat chain=srcnat dst-address=10.14.10.10/16 to-addresses=10.10.10.9/25
add action=src-nat chain=srcnat disabled=yes dst-address=10.10.10.9/25 to-addresses=10.14.10.10/16
/ip ipsec identity
/ip ipsec policy
add dst-address=10.14.10.10/16 peer=OURPEER proposal=IPSec_Crypto src-address=10.10.10.9/25 tunnel=yes
set 1 disabled=yes
/ip ipsec settings
set accounting=no
/system clock
/system identity
set name=OURPEER
/tool mac-server
thanks
Is like you do not understand: set both IP to bridge, not to etherX
If you have a dhcp-client, why set a fixed route?
remove this:
the first rule make perfectly useless the second
Remove the first rule
  1. add action=accept chain=srcnat dst-address=RR.RR.RR.RR/16 src-address=AA.AA.AA.AB/25
  2. add action=src-nat chain=srcnat dst-address=RR.RR.RR.RR/16 to-addresses=AA.AA.AA.AB/25
the fourth rule make perfectly useless the fifth
Remove the fourth rule
4) add action=masquerade chain=srcnat
5) add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
remove this:
==> i had delete it
sorry i hadn’t understood, can you help me please
Really???
Copy & Paste this on terminal
set [find where interface=ether2] interface=bridge
set [find where interface=ether5] interface=bridge
thanks, but it still doesn't work :frowning:
Did you do the other things too?
Reread my previous post, I probably wrote something you didn’t read because I added it later.
My first goal is to make your setup clear of nonsense.
I think so, I had read and corrected my errors, take a look at my new export:
 export
# aug/06/2021 13:09:35 by RouterOS 6.47.10
# software id =
# serial number =
add admin-mac=zz:zz:zz:zz:zz:zz auto-mac=no comment=defconf name=bridge
/interface wireless
/ip hotspot profile
/ip ipsec profile
    IKE_Crypto
/ip ipsec peer
/ip ipsec proposal
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.10.10.10/25 interface=bridge network=10.10.10.9
/ip dhcp-client
/ip dns static
add action=masquerade chain=srcnat comment="\"defconf: masquerad\"ipsec-policy=out,none out-interface-list=WAN"
/ip ipsec identity
/ip ipsec policy
set 1 disabled=yes
/ip ipsec settings
set accounting=no
/system clock
/system identity
set name=OURPEER
/tool mac-server
thanks
Little detail, remove b (leaving only 2ghz-g/n)
and something strange happen on NAT: masquerad"ipsec
output is traffic GENERATED from rotuerboard, not from any devices on all the networks!
Paste this, fix all what I have easily noticed, do not omit the { } !!!
/interface wireless set [ find default-name=wlan1 ] band=2ghz-g/n
remove [find]
after fixing it, try again, if not work post again the config, for search if any other problem.
You can’t ping ether1 192.168.1.25 from 192.168.88.x/24 network or from the remote 10.x.x.x/x?
yesss yesss yesss, , now i can ping but my VPN IPSec still Down,
ip ipsec policy print
Flags: T - template, B - backup, X - disabled, D - dynamic, I - invalid, A - active, * - default
 #      PEER             TUNNEL SRC-ADDRESS                                      DST-ADDRESS                                            PROTOCOL   ACTION  LEVEL    PH2-COUNT
 0      OURPEER           yes   10.10.10.9/25                                      10.14.10.10/16                                          all        encrypt require          0
 1 T X*                         ::/0                                             ::/0                                                   all
paste this, but do not move the rules on top:
i had added it, and not move it on top, but still don't UP, :confused: :frowning:
export again
yes my dear,
 export
# aug/06/2021 14:33:18 by RouterOS 6.47.10
# software id =
# serial number =
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge \
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=indoor mode=\
/ip hotspot profile
/ip ipsec profile
add dh-group=modp1024 dpd-interval=5s dpd-maximum-failures=100 enc-algorithm=aes-256,aes-128 lifetime=6h name=IKE_Crypto
/ip ipsec peer
/ip ipsec proposal
/ip dhcp-client
/ip dns static
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ipsec identity
/ip ipsec policy
set 1 disabled=yes
/ip ipsec settings
set accounting=no
/system clock
/system identity
set name=OURPEER
/tool mac-server
thanks
Ok the key is the NAT
what output you have to
/interface print
for address :
ip address print
 0   ;;; defconf
     192.168.88.1/24    192.168.88.0    bridge
 1   10.10.10.10/25     10.10.10.9      bridge
for interface :
interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1598       9214 zz:zz:zz:zz:zz:E5
 1  RS ether2                              ether            1500  1598       9214 zz:zz:zz:zz:zz:E6
 2   S ether3                              ether            1500  1598       9214 zz:zz:zz:zz:zz:E7
 3   S ether4                              ether            1500  1598       9214 zz:zz:zz:zz:zz:E8
 4   S ether5                              ether            1500  1598       9214 zz:zz:zz:zz:zz:E9
 5   S wlan1                               wlan             1500  1600       2290 zz:zz:zz:zz:zz:EA
 6  RS wlan2                               wlan             1500  1600       2290 zz:zz:zz:zz:zz:EB
 7  R  ;;; defconf
       bridge                              bridge           1500  1598            zz:zz:zz:zz:zz:E6
ok paste this, do not omit { }
this restore previous rules on first export
try to disable / enable one at time on winbox the first two rules (do not disable the last)
the third are already disabled on first export
remove [find]
add action=src-nat chain=srcnat disabled=yes dst-address=10.14.10.10/16 to-addresses=10.10.10.9/25
