1st LAN card “sat link” for the wan public internet by the satellite whit this IP for example 10.50.180.100/28 and its dynamic
2nd LAN cad “local net” for the wan public internet by local wireless service whit this IP for example 192.168.6.6/24 static
3rd LAN cad “local LAN” for the our local network whit this IP for example 192.168.1.0/24 manged by DHCP in MT router
I need solution step by step :
1- The basic connectivity to the internet
2-The DHCP configuration
3-The webcash service configuration
4-Load Balancing in"sat link" 60% and "local net"40% also can take fail over if one gos down automatically switch to 100% to the available connection
4-The firewall should block each and every thing just open the Browsing and MSN,yahoo,download,..etc and toruant service only
no ports for virus use or port forwarding or netcut “ARP”
5- make the access to the MT router from specific IP only in “LAN”
finally i make the connection and the DHCP all by the bridge
but still i cant configure the web proxy its working and caching but not fast its like the normal connection
also alot of problems in load balancing whit DHCP and DNS
also i get small problem in the “local net” the download and VOIP blocked how can i forward the download and VOIP to the “Sat link” also avoid the ISA server pages in the “LOCAL net”
for example :
i enter an forbidden site or start the download i will get the forbidden page from ISA server so…
how can i redirect any answer "or any page for the ISA server " to My own pages if its forbidding or not found site ???
and how can i redirect all traffics hold download or VOIP information from "local net " TO "sat link " ???
any one can give me solution or at lest a key to solve my problems !!!
Dear Ashish ;
Glad to write again .
kindly i would like to get permission to add your msn address to my list so i could frequently ask you some questions about the Mikrotik OS .
here i would like to say that the MikroTik site should put the guides in a way how to configure the MT not in catgory like now which it confusing most who read them
waiting your reply .
with best regards .
