Hello everyone,
I’m facing a strange issue on my MikroTik network and need some help troubleshooting it.
Problem:
Clients are getting “Connected, No Internet” / “Connected without Internet” messages randomly, even though everything appears to be working normally.
Current Situation:
Internet is actually working for many sites/services
Ping to public IPs (like 8.8.8.8) works
DNS seems mostly fine
MikroTik CPU/RAM usage is normal
No packet loss found in basic tests
WAN interface stays connected
DHCP is assigning IPs correctly
Clients can sometimes browse normally, but Windows/Android still says “No Internet”
Issue happens on multiple devices
What I already checked:
DNS configuration
Gateway reachability
DHCP lease settings
NAT masquerade rules
Firewall rules
MTU/MSS
FastTrack
IPv6 disabled for testing
Changed DNS to Google/Cloudflare
Rebooted router and ONU
Tested with different devices
Environment:
Router: MikroTik
Clients: Windows + Android
ISP connection stable
No major bandwidth saturation
Possible Symptoms:
Sometimes captive portal detection fails
Sometimes apps work but browser shows limited connection
Random intermittent issue
Has anyone experienced this before?
Could this be related to:
DNS timeout?
MTU/MSS issue?
IPv6?
FastTrack?
TCP/UDP blocking?
Windows NCSI detection?
ISP-side routing issue?
Any suggestions on what else I should check would be appreciated.
Thanks.
