Hello everyone,
I apologize if similar was asked. Iam begginer with Mikrotik and networking.
I was inspired by coleges that Mikrotik is great ruters and switches, so i got 1 to replace current router that I have. I am trying to configure it for past 14 days. One day 50% works and other 50% not, Next day is vice versa.
What i use as equipment:
- 1x L009UiGS
- 2x Netgeat GS108Tv3
- 1x TP-link TL-SG108E
- 1x Netgear GS105E
I want to use 4 VLANs to separate management, laptops, IOT devices and VMWare servers.
-vlan 100 - mgmt
-vlan 200 - laptops
-vlan 800 - IOT
-vlan 1000 - VMWare
L009 port:
- sfp - internet
- ether1 to ether4 VLAN 200
- ether5 to ether8 TRUNK to each switch
- each port 1 on switches is trunk
- other ports i managed to set with VLNAs 100,200,800,1000
Each switch has static IP for VLAN100 static assigned
Currently working:
4 trunk ports connecting to switches work. Each port on switch that has different VLAN assigned takes IP from DHCP's on router.
First 4 ports on L009 ethr1 - ethr4 refuse to give dhcp ips. If I turn on VLAN filetring on Bridge --> situation turns 180 degress.
ethr1 to ethr4 works normally and gives DHCP addresses, and Trunk side just dies and doesnt want to give anything.
I would assume there is some small mistake somewhere. attaching config what i did.
Thanks in advance for suggestinons.
# 2024-03-01 15:53:47 by RouterOS 7.14
# software id = XXXXXXXXXX
# model = L009UiGS
# serial number = XXXXXXXXXX
add admin-mac=XXXXXXXXXX auto-mac=no mtu=1500 name=TrunkBridge
/interface vlan
add interface=TrunkBridge name="Desktop V200" vlan-id=200
add interface=TrunkBridge name="IOT V800" vlan-id=800
add interface=TrunkBridge name="MGMT V100" vlan-id=100
add interface=TrunkBridge name="VMWare V1000" vlan-id=1000
add comment=defconf name=WAN
add comment=defconf name=LAN
add name="MGMT pool" ranges=192.168.250.111-192.168.250.122
add name="IOT pool" ranges=192.168.8.111-192.168.8.150
add name="vmware pool" ranges=192.168.200.50-192.168.200.90
add name="desktop pool" ranges=192.168.10.105-192.168.10.200
add add-arp=yes address-pool="MGMT pool" interface="MGMT V100" name=\
"MGMT 250 dhcp"
add add-arp=yes address-pool="IOT pool" interface="IOT V800" name=\
"IOT 8 DHCP"
add add-arp=yes address-pool="vmware pool" interface="VMWare V1000" name=\
"vmware V1000 DHCP"
add add-arp=yes address-pool="desktop pool" interface="Desktop V200" name=\
"Desktop V200 DHCP"
/ip smb users
/port
set 0 name=serial0
add bridge=TrunkBridge frame-types=admit-only-vlan-tagged interface=ether5
add bridge=TrunkBridge frame-types=admit-only-vlan-tagged interface=ether6
add bridge=TrunkBridge frame-types=admit-only-vlan-tagged interface=ether7
add bridge=TrunkBridge frame-types=admit-only-vlan-tagged interface=ether8
add bridge=TrunkBridge frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=no interface=ether2 pvid=200
interface=ether3 pvid=200
interface=ether4 pvid=200
interface=ether1 pvid=200
set udp-timeout=10s
/interface bridge vlan
add bridge=TrunkBridge tagged=TrunkBridge,ether5,ether6,ether7,ether8 \
untagged=ether1,ether2,ether3,ether4 vlan-ids=200
add interface=TrunkBridge list=LAN
add interface=sfp1 list=WAN
add address=192.168.250.1/24 interface="MGMT V100" network=192.168.250.0
add address=192.168.8.1/24 interface="IOT V800" network=192.168.8.0
add address=192.168.200.1/24 interface="VMWare V1000" network=192.168.200.0
add address=192.168.10.1/24 interface="Desktop V200" network=192.168.10.0
/ip arp
add address=192.168.250.3 interface="MGMT V100" mac-address=08:36:C9:19:16:30
add address=192.168.250.4 interface="MGMT V100" mac-address=08:36:C9:19:16:64
/ip dhcp-client
add interface=sfp1
add address=192.168.8.0/24 gateway=192.168.8.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.200.0/24 gateway=192.168.200.1
add address=192.168.250.0/24 gateway=192.168.250.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Jupiter/Europa
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
