i need help setting up moto ap's in the dude
i came into a project after it was mostly done. so i am not sure whats going on fully. we changed color codes and added some AP’s. what i cant figure out is how to change the color code is shows. and how to get the new APs to show the color codes they have. here is a screen shot. AP 1-4 now have different color codes but i can change this. and obviously AP 5 & 6 are not showing up correctly…thanks for any help
Not sure if this is waht you are searching for but you can right click and you have appearance. In this menu you can customize the display of your AP
holy crap that did it…something so simple i over looked. thank you VERY much :slight_smile: :slight_smile:
Is there a way I can change the appearance of lots of APs quickly?
on top of the map, hit settings, and go into Appearance there. it also has device color settings
Thank you for the information you provided. It helped alot.
[u]comparatif simulation assurance vie multisupport[/u] - simulation assurance vie ! Les sites de simulation assurance vie[u]comparatif simulation assurance vie multisupport[/u]
