Welcome how are you?
I have Wireless network of ubiquiti xr2 and Antena hyperlink omni 15dbi and a mikrotik system on the desktop
I have a problem that is the side of the house high voltage electric wire , It is making noise of the signal and Bandwet
Is there a solution to the high-voltage electricity pylons
I would firstly try either shifting channels to see if it makes any difference, then try the mikrotik’s adaptive noise immunity settings.
thank you
I changed the channels several times but to no avail.
But what the mikrotik’s adaptive noise immunity settings for the electricity pylons
jwcn
5
What version of ROS are you using?
