How many ports? How many watts? PoE++ (802.3bt) is 60W or 100W. Driving that much power, what use case? Might be cheaper to build a shelf with injector bricks for just what you need.
Netgear also sells its slightly cheaper predecessor, the MS510TXPP.
Main difference is slower ports and a reduction of PoE power from 60W per port to 30W per port. UP is PoE++60 with 4x2.5, 4x10GbE, & 2xSFP+. PP is PoE+ with 4x1GbE, 2x2.5GbE, 2x5GbE, 1x10GbE, 1xSFP+. Otherwise, both end up being 10 port switches with internal non redundant power supplies.
I have the latter switch. It’s mostly okay, with no serious complaints from me. Fan is a bit noisy and it does output some heat (especially for a switch). I am slowly migrating my network away from it and migrating my PoE devices where I can. Managed PoE is nice, but I’ve only ever used the management to reboot a failed device. Since I upgraded my primary wifi access point to a Ruckus H510 about a year ago, I’ve never had to do that.
Of course, with my luck, the moment I migrate away from a managed PoE switch, Ruckus’ engineering will go down the tubes and I will miss managed PoE.
The H510 has been the problem solver for me for years now!
Man cave.
Back Office at the restaurant
Addition to the home where the wall used to be exterior
Under the desk in the bosses office
etc
etc
etc
However… I have run into a lot of connectivity issues with ALL THE FIRMWARES forward of 212 released November 2020.
As the change over to WiFi6 hardware has happened at Ruckus… when I get rid of my last 2 H510s… the H550 ain’t gonna work with my TRIED TESTED AND TRUE firmware 212.
Hence why I have had to SERIOUSLY consider changing WIFI vendors, after over 10 years as my GOTO.
That is disappointing to hear. I only have one access point (and live in an extremely RF dense environment - near an airport, and there are 80+ wifi access points that I can see from my computer), and the H510 has worked the best out of 5+ different access points I have tested (cap ac, netgear wax214 [engenius ews357 rebrand], netgear generic ac from walmart, raspberry pi with hostapd, etc).
I’m currently experimenting with setting up my own access point with a collection of Mediatek WiFi 6 and 6E hardware, a SBC, hostapd, and Linux kernel 5.15+ (which sadly excludes my Raspberry Pi CM4 for now, though Raspberry Pi corp is experimenting with 5.15 at the moment; needs 5.15 for 6E support using my Mediatek cards - Mediatek and Qualcomm cards still support AP mode, unlike Intel cards. QCA has been drifting away from OSS drivers, while Mediatek has been getting better). I think I’ll eventually just simplify it to a single card with 2 tri-band antennas, instead of my current 3 card, 8 antenna setup.
EDIT: I guess I’ve drifted from the topic of this thread. Thanks for your input on the H510’s trajectory. Still using it for now, but I am trying to replace it sooner than later.
The cAP AC in busy 2.4 areas have cost me thousands.
Had to replace them out of pocket and down have anything in the price range now. In 5Ghz… It gets by. But 2.4 only iot like devices were a disaster.
I am gonna get an UNWANTED up close view of the current Engenius. I have a deep seated disdain for that company.
UniF–k… I have to buy one of them each time the put out a new model. Just so I know everything that’s gonna go wrong when another trade insists on putting them in my network.
Cambium XV2-2 was supposed to arrive Friday. Currently lost in UPS snow delays. Maybe I will get it in here tomorrow.
i dont find very realistic the need for a 2.5gigabit ethernet for a single access-point in real world scenarios, in 95% of cases 1gigabit will be more than enough
off course in a green-field benchmark with special clients in ideal conditions maybe you can saturate a 1 gigabit uplink
but not with real usage
most 2.5 gigabit AP are compatible with 1 gigabit so you can deploy using 1 gigabit ethernet and when supply chain crisis passes you will have plenty of options to upgrade to 2.5 gigabit if you find it really useful
