I want scripts CHANGEIP V 5.26
I want scripts CHANGEIP MikroTik V 5.26
You can find answer here:
http://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_ChangeIP.com
Use this script:
# EDIT YOUR DETAILS / CONFIGURATION HERE
:global ddnsuser "YourChangeIPUserID"
:global ddnspass "PASSWORD"
:global ddnshost "MyRouterHostname.example.org"
:global ddnsinterface "ether1"
# END OF USER DEFINED CONFIGURATION
:global ddnssystem ("mt-" . [/system package get [/system package find name=system] version] )
:global ddnsip [ /ip address get [/ip address find interface=$ddnsinterface] address ]
:global ddnslastip
:if ([:len [/interface find name=$ddnsinterface]] = 0 ) do={ :log info "DDNS: No interface named $ddnsinterface, please check configuration." }
:if ([ :typeof $ddnslastip ] = "nothing" ) do={ :global ddnslastip 0.0.0.0/0 }
:if ([ :typeof $ddnsip ] = "nothing" ) do={
:log info ("DDNS: No ip address present on " . $ddnsinterface . ", please check.")
} else={
  :if ($ddnsip != $ddnslastip) do={
    :log info "DDNS: Sending UPDATE!"
    :log info [ :put [/tool dns-update name=$ddnshost address=[:pick $ddnsip 0 [:find $ddnsip "/"] ] key-name=$ddnsuser key=$ddnspass ] ]
    :global ddnslastip $ddnsip
  } else={
    :log info "DDNS: No changes necessary."
# END OF SCRIPT
And at the end add scheduler to run this script.
/system scheduler add name=dynDNS interval=00:01 on-event="/system script run "Name of your script"\r\n"
