ICMP PING timeout outside LAN
as a brand new hAP ac2 MikroTik user after configuring LTE USB modem (with some help from the interwebs) I have issues with PING timeouts outside of my LAN.
It was working just fine initially when I’ve just connected the LTE modem into USB after resetting MikroTik to defaults (I was able to ping from router terminal through lte1 interface)
But after finishing the DHCP settings, firewall masquerade and so on it just stopped working.
while local IP PINGs are working fine. I’ve tried multiple (propably stupid) things so sorry if my config is somewhat screwed up.
I’ve set up a log so I can actually see the firewall rule to forward ICMP packages is working just fine and packages are forwarded to correct interface (lte1):
in:bridge out:lte1, src-mac fc:aa:14:c4:c6:57, proto ICMP (type 8, code 0), 192.168.1.3->172.217.16.46, len 60
Even trying to PING from the router Terminal ends up with timeout:
/export hide-sensitive compact
# jan/13/2021 00:54:54 by RouterOS 6.46.8
# software id = ZHG8-EQ57
# model = RBD52G-5HacD2HnD
# serial number = B4A00A597C41
add admin-mac=74:4D:28:5E:00:68 auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] mac-address=36:4B:50:B7:EF:2D name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk management-protection=allowed mode=dynamic-keys name=WPA2 supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn country=poland disabled=no distance=indoors frequency=2462 installation=indoor mode=ap-bridge security-profile=WPA2 ssid=XXX1 wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=poland disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge security-profile=WPA2 ssid=XXX2 wireless-protocol=802.11 wps-mode=disabled
/ip hotspot profile
add name=default-dhcp ranges=192.168.1.2-192.168.1.254
add address-pool=default-dhcp disabled=no interface=bridge lease-time=30m name=defconf
/queue simple
add limit-at=2M/2M max-limit=2M/2M name=ICMP packet-marks=icmp_pkt target=""
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.1.2 mac-address=9C:B7:0D:C0:54:1D server=defconf
add address=192.168.1.3 client-id=1:fc:aa:14:c4:c6:57 mac-address=FC:AA:14:C4:C6:57 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add address=192.168.1.3 name=uriziel.local
add action=accept chain=forward log=yes log-prefix=ICMPP protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward out-interface=lte1
add action=accept chain=forward in-interface=lte1
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=from-dscp-high-3-bits passthrough=yes
add action=mark-connection chain=prerouting new-connection-mark=icmp_conn passthrough=yes protocol=icmp
add action=mark-packet chain=prerouting connection-mark=icmp_conn new-packet-mark=icmp_pkt passthrough=no protocol=icmp
add action=masquerade chain=srcnat out-interface=lte1
add action=redirect chain=dstnat dst-port=53 protocol=tcp
add action=redirect chain=dstnat dst-port=53 protocol=udp
/ip service
set ftp disabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system package update
set channel=testing
/tool graphing interface
add interface=wlan1 store-on-disk=no
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
Remove the below rules and add lte interface to WAN interface list
