I setup igmp-proxy on my hEX PoE for IPTV and I get stream on my tuner.
However, it looks like traffic is passing on all ports on the hEX and not just the port to the tuner. How can I limit this?
This is what I got:
Thanks for the link, nikc.
I followed a short howto that looks a lot like this one to get where I am.
What is different from my setup is that the input UDP firewall rule is not needed and does not look to make a difference? I only need the igmp input rule and the UDP follow rule.
Also regarding the igmp-proxy settings, the guides says to set the downstream interface to the one where the stb/tuner is connected. Mine only works if I chose the bridge for downstream. Why is that?
