Hi!
This is first time I have ever configured IKE2 RSA Road Warrior, I followed this tutorial - https://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Road_Warrior_setup_using_IKEv2_with_RSA_authentication
Current DHCP for LAN - 10.0.0.10-10.0.0.70
I have two site-to-site IPsec tunnels configured as well - 10.0.0.0/24-10.14.14.0/24 and 10.0.0.0/24-10.23.23.0/24
Configuration I made, all firewall rules included -
/certificate
add common-name=XX.XX.XX.XX name=XX.XX.XX.XX
sign "XX.XX.XX.XX" ca-crl-host=XX.XX.XX.XX
add common-name=XX.XX.XX.XX subject-alt-name=IP:XX.XX.XX.XX key-usage=tls-server name="IKE2 RSA server"
sign "IKE2 RSA server" ca=XX.XX.XX.XX
add common-name=Client name=Client key-usage=tls-client
sign Client ca=XX.XX.XX.XX
/ip ipsec policy group
add name="IKE2 RSA"
/ip ipsec profile
add dh-group=modp1024 dpd-interval=10s enc-algorithm=aes-256 hash-algorithm=\
sha256 lifetime=8h name="IKE2 RSA"
/ip ipsec peer
add exchange-mode=ike2 local-address=XX.XX.XX.XX name="IKE2 RSA" passive=\
yes profile="IKE2 RSA"
/ip ipsec proposal
add enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=1h name="IKE2 RSA" \
pfs-group=none
add name="IKE2 RSA" ranges=10.0.0.81-10.0.0.89
/ip ipsec mode-config
add address-pool="IKE2 RSA" address-prefix-length=32 name="IKE2 RSA"
/ip firewall address-list
add address=10.0.0.81 list="IKE2 RSA"
add address=10.0.0.82 list="IKE2 RSA"
add address=10.0.0.83 list="IKE2 RSA"
add address=10.0.0.84 list="IKE2 RSA"
add address=10.0.0.85 list="IKE2 RSA"
add address=10.0.0.86 list="IKE2 RSA"
add address=10.0.0.87 list="IKE2 RSA"
add address=10.0.0.88 list="IKE2 RSA"
add address=10.0.0.89 list="IKE2 RSA"
add action=accept chain=input comment="Router fw input accept all active" \
add action=accept chain=input comment="IKE2 RSA" in-interface-list=WAN port=\
500,4500 protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
add action=drop chain=input comment="Router fw input drop invalid" \
connection-state=invalid
add action=drop chain=input comment="Router fw input drop all not from LAN" \
in-interface-list=!LAN
add action=accept chain=forward comment="Router fw IPsec in accept" \
ipsec-policy=in,ipsec
add action=accept chain=forward comment="Router fw IPsec out accept" \
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=\
"Router fw forward fasttrack" connection-state=established,related
add action=accept chain=forward comment="Router fw forward accept all active" \
add action=drop chain=forward comment="Router fw forward drop invalid" \
"Router fw forward drop all from WAN not dstnated" connection-nat-state=\
!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=srcnat comment="Tunnel-1" dst-address=\
10.14.14.0/24 src-address=10.0.0.0/24
add action=accept chain=srcnat comment="Tunnel-2" dst-address=\
10.23.23.0/24 src-address=10.0.0.0/24
add action=masquerade chain=srcnat comment="Router fw masquerade" \
/ip ipsec identity
add auth-method=digital-signature certificate="IKE2 RSA server" \
generate-policy=port-strict match-by=certificate mode-config="IKE2 RSA" \
peer="IKE2 RSA" policy-template-group="IKE2 RSA" remote-certificate=\
"Client"
/ip ipsec policy
add dst-address=10.0.0.0/24 group="IKE2 RSA" proposal="IKE2 RSA" src-address=\
0.0.0.0/0 template=yes
After that I exported client certificate as pkcs12, imported it to Windows 10 machine and created new VPN profile. I can connect to VPN, I can ping and access to 10.14.14.0/24 and 10.23.23.0/24 networks, but I can’t ping and access to any device located in LAN 10.0.0.0/24 network.
Do I have to add additional firewall rules? Thanks!
