Anyone have luck that configure the Ikev2 vpn on Mikrotik for Android 13?
If yes, please share how to do it.
Thank you
Thank you
It is impossible to configure via eap radius, most likely a problem on the part of Mikrotik. I managed to configure through authentication with 2 CA certificates and the client in Mikrotik identity is a digital signature
good morning, I made a guide that works on some phones but not on all. it works for me on samsung but not on xiaomi
https://foisfabio.it/index.php/2023/03/02/mikrotik-ikev2/
EAP is working fine on MT. Use Strongswan on Android clients.
Here is a working configuration of ipsec ikev2 / psk vpn:
notes:
1.this configuration is NOT touching the “default” profile, “default” identity etc. So it should work in parallel with other VPN types, for instance in paralell with L2TP/ipsec VPN which is creating dynamic identity/peer and cannot use anything else than default. So this configuration is glued together by a group named “ike2-group”
2. Android still claims this VPN as “insecure” however I did not dig deeper, I wanted to just “make it work” because L2TP was removed.
3. You need to alter below scripts a bit, by filling in the [TEXT IN BRACKETS] with your names/passwords etc.
4. you need to create address pool for the VPN connections first, and give the pool’s name as [ADDRESS_POOL] below
5. [FULL_DOMAIN_NAME_OF_ROUTER] is DNS name under which router will be available (like www.google.com)
6. [SECRET] is your pre-shared key.
7. In Android you have to give such VPN settings:
“name” whatever you like.
“type” is “IKEv2/IPSec PSK”
“Server address” the same as in [FULL_DOMAIN_NAME_OF_ROUTER]
“IPsec identifier” the same as in [FULL_DOMAIN_NAME_OF_ROUTER]
“Pre shared key” the same as in [SECRET]
8. Maybe proposal could be simplified. I was adding everything till it started to work.
# 2024-06-16 21:14:19 by RouterOS 7.13.2
# model = RB3011UiAS
/ip ipsec policy group
add name=ike2-group
/ip ipsec mode-config
add address-pool=[ADDRESS_POOL] name=ike2-config
/ip ipsec profile
add dh-group=ecp256,ecp384,ecp521,modp8192,modp6144,modp4096,modp3072,modp2048 enc-algorithm=aes-256,aes-192,aes-128 hash-algorithm=sha512 name=ike2-profile proposal-check=claim
/ip ipsec peer
add exchange-mode=ike2 name=ike2-peer passive=yes profile=ike2-profile secret=[SECRET]
/ip ipsec proposal
add auth-algorithms=sha512,sha256 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-cbc,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm name=ike2-proposal pfs-group=\
modp4096
/ip ipsec identity
add comment="identity to be used in ikev2" generate-policy=port-strict mode-config=ike2-config my-id=fqdn:[FULL_DOMAIN_NAME_OF_ROUTER]\
peer=ike2-peer policy-template-group=ike2-group
/ip ipsec policy
add comment="policy to be used in ike2-identity and ike2-policy" dst-address=0.0.0.0/0 group=ike2-group proposal=ike2-proposal src-address=0.0.0.0/0 template=yes
Thank you very much, Damago.
I was having trouble configuring the VPN for some time after my cell phone updated.
A big hug
This is the only configuration that works. I think because of this line:
The “my-id=fqdn:[FULL_DOMAIN_NAME_OF_ROUTER]\ “ resolves the vpn connection.
Thanks!
Yes, this is how strongswan in android works
It works even with the native android client.
