Hi everyone!
Looking for a help in configuring DNS in IKEv2. Internal routing is done via L3-switch. Switch routes traffic through vlan150 to MT. Local network to access through VPN is in vlan100. AD DNS servers are in vlan 200. All addresses are in format 10.vlanid.x.x (e.g. DNS servers are 10.200.0.x, LAN addresses are 10.100.x.x). I do include 10.100.0.0/16 as split-include. Windows clients only accept first split-include, so I can’t also include DNS-subnet. Can I add some sort of “virtual” IP to DNS property of split-include, and forward traffic to it internally into the real internal IPs? Like add something like 10.100.255.254 and NAT it to 10.200.0.x?
Here’s related configuration parts:
# apr/16/2024 00:22:45 by RouterOS 6.49.13
# software id = 6TTH-KAVK
# model = 2011iL
# serial number = 5BEC04B45E97
/interface bonding
add forced-mac-address=4C:5E:0C:EC:67:2E lacp-rate=1sec mode=802.3ad name=\
switchLacp slaves=ether4,ether2 transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=switchLacp name=InternetOnly vlan-id=50
add interface=switchLacp name=LAN vlan-id=100
add interface=switchLacp name=Management vlan-id=20
add interface=switchLacp name=RouterGW vlan-id=150
add arp=reply-only interface=switchLacp name=Voice vlan-id=40
add arp=reply-only interface=switchLacp name=WiFi vlan-id=10
add name=Gateway
/ip ipsec policy group
add name=IKEv2
/ip ipsec profile
add enc-algorithm=aes-256,aes-128 hash-algorithm=sha256 name=IKEv2Profile
/ip ipsec peer
add exchange-mode=ike2 local-address=*WHITE_IP* name=IKEv2Peer passive=\
yes profile=IKEv2Profile
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms="aes-256-cbc,aes-256-ctr\
,aes-256-gcm,aes-192-cbc,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,a\
es-128-gcm" lifetime=1h name=proposal_IKEv2 pfs-group=none
add name=l2tpPool ranges=192.168.230.0/24
add name=IKEv2Pool ranges=192.168.210.2-192.168.210.254
add name=DHCP_InternetOnly ranges=10.50.0.2-10.50.255.254
/ip ipsec mode-config
add address-pool=IKEv2Pool address-prefix-length=16 name=IKE split-include=\
10.100.0.0/16 static-dns=10.100.0.10 system-dns=no
add address-pool=IKEv2Pool name=ManagementVLAN split-include=10.20.0.0/16
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/certificate settings
set crl-use=yes
/interface l2tp-server server
set authentication=mschap2 default-profile=VPN230 enabled=yes use-ipsec=yes
add interface=ether1 list=Gateway
add address=*WHITE_IP*/25 comment=WAN interface=ether1 network=\
*ISP_GW*
add address=10.10.0.2/16 interface=WiFi network=10.10.0.0
add address=10.150.0.2/30 interface=RouterGW network=10.150.0.0
add address=10.40.0.1/16 interface=Voice network=10.40.0.0
add address=10.50.0.1/16 interface=InternetOnly network=10.50.0.0
/ip dhcp-client
add disabled=no interface=Management
add disabled=no interface=WiFi
add dhcp-options=clientid disabled=no interface=LAN
/ip firewall address-list
add address=*WHITE_IP* list=RealIP
add address=10.100.0.0/16 list="Hairpin NAT"
add address=10.10.0.0/16 list="Hairpin NAT"
add address=192.168.188.0/24 list="Hairpin NAT"
add action=add-src-to-address-list address-list=port_scanners \
address-list-timeout=2w chain=input comment="Port scanners to list" \
in-interface-list=Gateway log=yes protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input in-interface-list=Gateway protocol=\
tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
tcp tcp-flags=fin,syn
tcp tcp-flags=syn,rst
tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
tcp tcp-flags=fin,syn,rst,psh,ack,urg
tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=accept chain=input connection-state=established,related
add action=accept chain=input comment=VPN dst-port=1701,500,4500 protocol=udp
add action=accept chain=input in-interface=Management
add action=drop chain=input
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward in-interface=RouterGW out-interface-list=\
Gateway
add action=accept chain=forward in-interface=WiFi out-interface-list=Gateway
add action=accept chain=forward in-interface=InternetOnly out-interface-list=\
Gateway
add action=accept chain=forward comment="Allow NAT" connection-nat-state=\
dstnat connection-state=new
add action=accept chain=forward comment="L2TP forward rule" in-interface=\
all-ppp out-interface=LAN
add action=accept chain=forward comment="IKEv2 forward rule" ipsec-policy=\
in,ipsec out-interface=LAN
add action=accept chain=forward dst-address=10.20.0.0/16 ipsec-policy=\
in,ipsec
add action=drop chain=forward comment="Drop everything else"
add action=src-nat chain=srcnat out-interface-list=Gateway to-addresses=\
*WHITE_IP*
add action=src-nat chain=srcnat src-address-list="Hairpin NAT" to-addresses=\
10.150.0.2
/ip firewall raw
add action=drop chain=prerouting log-prefix="port_scanner drop" \
src-address-list=port_scanners
add action=drop chain=prerouting src-address-list=Blacklist
/ip ipsec policy
add dst-address=192.168.210.0/24 group=IKEv2 proposal=proposal_IKEv2 \
src-address=0.0.0.0/0 template=yes
add check-gateway=ping distance=1 gateway=*ISP_GW*
add distance=1 dst-address=10.200.0.0/29 gateway=10.150.0.1 pref-src=\
10.150.0.2
