I have an Script:
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=5ghz-a/n/ac\
channel-width=20/40/80mhz-XXXX country=no_country_set disable-running-check=yes disabled=no frequency=auto \
frequency-mode=superchannel hw-retries=15 installation=any l2mtu=2290 mode=station-bridge nv2-preshared-key=xxx \
nv2-security=enabled radio-name=NNNNNN-nutzer \
scan-list=5180,5200,5220,5240,5260,5280,5300,5320,5500,5520,5540,5560,5580,5600,5620,5640,5660,5680,5700,5770,5790,5810,5830,5850,default \
ssid=SSID tx-power=22 tx-power-mode=all-rates-fixed wireless-protocol=nv2-nstreme-802.11
/interface wireless nstreme
set wlan1 enable-nstreme=yes
delay 2
add mtu=1500 name=bridge1 protocol-mode=none
set [ find default=yes ] authentication-types=wpa2-psk group-key-update=1h management-protection=allowed \
management-protection-key=xxx mode=dynamic-keys supplicant-identity=MikroTik \
wpa2-pre-shared-key=xxx
/interface bridge filter
add action=accept chain=forward comment="allow PPPoE-Discovery" mac-protocol=pppoe-discovery
add action=accept chain=forward comment="allow PPPoE-Session" mac-protocol=pppoe
add action=drop chain=forward comment="Block all other"
add action=drop chain=input comment="Block all other from ether1" disabled=yes in-interface=ether1
add bridge=bridge1 interface=wlan1
delay 2
/system ntp client
set enabled=yes primary-ntp=10.0.250.13 secondary-ntp=10.0.250.13
/tool graphing interface
add
/tool graphing resource
add
/system clock
/system script
add name=txpower policy=ftp,reboot,read,write source=":global txpowerold [/interface wireless get [ find interface=wlan1 ] tx-\
power];\r\
\n:global txstrengthold [/interface wireless registration-table get [ find interface=wlan1 ] \
tx-signal-strength];\r\
\n:global txregel [/interface wireless get [ find interface=wlan1 ] tx-power-mode];\r\
\n\r\
\nif (\$txregel = \"default\") do={\r\
\n\t/interface wireless set [ find interface=wlan1 ] tx-power-mode=all-rates-fixed;\r\
\n\t/interface wireless set [ find interface=wlan1 ] tx-power=20;\r\
\n\t:log info tx-regel-angepasst;}\r\
\nif (\$txpowerold < 23 && \$txstrengthold < -65) do={ \r\
\n\t/interface wireless set [ find interface=wlan1 ] tx-power=(\$txpowerold + 2);\r\
\n\t:log info tx-2-hoch;}\r\
\nif (\$txpowerold > 6 && \$txstrengthold > -60) do={\r\
\n\t/interface wireless set [ find interface=wlan1 ] tx-power=(\$txpowerold - 2);\r\
\n\t:log info tx-2-weniger;}\r\
\n\t/int bri fil ena [find];\r\
\n:log info durchlauf;\r\
\n"
add name=biosup policy=ftp,reboot,read,write source=":if ( [ /system routerboard get upgrade-firmware ] > [ /system routerboard get current-firmwar\
e ] ) do={ /system routerboard upgrade; /delay 10; /system reboot; }"
/system scheduler
add interval=1d name=schedule1 on-event="/sys script run txpower;" \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive \
start-date=jan/01/1970 start-time=03:00:00
add interval=1d name=schedule2 on-event="/sys script run biosup;" \
start-date=mar/18/2014 start-time=02:00:00
/ip dhcp-client
add add-default-route=yes comment="" disabled=no \
interface=bridge1 use-peer-ntp=yes
/system identity
set name="o-NNNNNN-nutzer"
/ip firewall connection tracking set enabled=no
/interface wireless set 0 disable-running-check=yes
But with “import script.rsc” The Winbox loose Connection and the Script will not work till the end. Why?
eth-Link goes down/up. That’s the reason, why the Winbox lost connection.
Why?
best regards
Christian
