Importing a hAP AC lite script into the hAP AC^2?
I have several hAP AC lite devices in use. Today I bought a hAP AC^2 to upgrade my living room router. I thought life can be easy, I export the settings from my living room AC lite device and import it in the AC^2.
It doesn’t work … ? I don’t get errors, but the script doesn’t run until the end, why not?
Strange thing is that the script stops on line 52, sometimes 53. Checked this whith the ‘verbose=yes’ option.
Then I get disconnected on WinBox. When I reconnect I can see that line 54 … are executed? It looks like the scrip is executed somewhere until halfway the firewall. An extra 30 lines affer 53 ??
Why not all the lines?
And how does the script looks like?
Post it using code tags button </>
Cut and past scrip to post, select script and click the code button above the post.
The complete code:
# jan/27/2021 11:19:45 by RouterOS 6.48
# software id = GAW3-8HWT
# model = RB952Ui-5ac2nD
# serial number = CC3E0C95F4A3
set [ find default-name=ether1 ] name=ether1_WAN
set [ find default-name=ether2 ] name=ether2_Direct
set [ find default-name=ether3 ] name=ether3_LAN
set [ find default-name=ether4 ] name=ether4_LAN
set [ find default-name=ether5 ] name=ether5_LAN
add name=bridge_Gast
add name=bridge_LAN_Wifi
add name=bridge_WAN
add name=WAN
add name=LAN
set [ find default=yes ] supplicant-identity=MkT_Living
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=\
    profile_Wifi supplicant-identity="" wpa2-pre-shared-key=********
    profile_Gast supplicant-identity="" wpa2-pre-shared-key=********
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
    country=belgium disabled=no frequency=2412 installation=indoor mode=\
    ap-bridge name=wlan_2.4 security-profile=profile_Wifi ssid=BaLiJuMa \
    wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-XXXX \
    country=belgium disabled=no frequency=5180 installation=indoor mode=\
    ap-bridge name=wlan_5 security-profile=profile_Wifi ssid=BaLiJuMa \
add default-forwarding=no disabled=no keepalive-frames=disabled mac-address=\
    4A:8F:5A:C4:BD:87 master-interface=wlan_2.4 multicast-buffering=disabled \
    name=wlan_Gast security-profile=profile_Gast ssid=GastWifi \
    wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
    4A:8F:5A:C4:BD:87 master-interface=wlan_5 multicast-buffering=disabled \
    name=wlan_Gast5 security-profile=profile_Gast ssid=GastWifi \
add name=dhcp_pool_LAN_Wifi ranges=192.168.2.2-192.168.2.254
add name=dhcp_pool_Gast ranges=192.168.102.2-192.168.102.254
add address-pool=dhcp_pool_LAN_Wifi disabled=no interface=bridge_LAN_Wifi \
    name=dhcp_LAN_Wifi
add address-pool=dhcp_pool_Gast disabled=no interface=bridge_Gast name=\
    dhcp_Gast
add bridge=bridge_WAN interface=ether2_Direct
add bridge=bridge_WAN interface=ether1_WAN
add bridge=bridge_LAN_Wifi interface=ether4_LAN
add bridge=bridge_LAN_Wifi interface=ether3_LAN
add bridge=bridge_LAN_Wifi interface=ether5_LAN
add bridge=bridge_LAN_Wifi interface=wlan_5
add bridge=bridge_LAN_Wifi interface=wlan_2.4
add bridge=bridge_Gast interface=wlan_Gast
add bridge=bridge_Gast interface=wlan_Gast5
add interface=bridge_WAN list=WAN
add interface=bridge_LAN_Wifi list=LAN
add address=192.168.2.1/24 interface=bridge_LAN_Wifi network=192.168.2.0
add address=192.168.1.2/24 interface=ether1_WAN network=192.168.1.0
add address=192.168.102.1/24 interface=bridge_Gast network=192.168.102.0
/ip dhcp-client
add address=192.168.2.0/24 dns-server=192.168.2.1,8.8.8.8,9.9.9.9 gateway=192.168.2.1
add address=192.168.102.0/24 gateway=192.168.102.1
set servers=192.168.1.1,8.8.8.8,8.8.4.4,9.9.9.9
/ip dns static
add address=192.168.2.1 name=MkT_Living
    established,related,untracked
    invalid
    "Gast netwerk geen toegang tot locale netwerk" dst-address=192.168.0.0/16 \
    src-address=192.168.102.0/24
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface-list=WAN src-address=\
    192.168.2.0/24
    192.168.102.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=192.168.1.1
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Brussels
/system identity
set name=MkT_Living
/system leds settings
set all-leds-off=after-1h
I’ve splitted my .rsc file in 3 files, all less than 50 lines. When I import these 3 files sequentially, there is no problem importing it into the AC^2 …! ?
If number of ports is the same, there is no difference what model you have. You can see in the export script, that apart from interfaces, most commands are neutral
Ok, so you have posted config of the router, not a script.
Id the problem is to get config from old router to new router, try to copy group by group of commands until it fails.
Then post her what does fail.
As Normis writes, the config should be rather equal on those two boxes.
Sorry, I’m new to MikroTik.
There is no fail, that’s the strange thing. The AC2 doesn’t run the complete import if I import the above config file at once. If I run it in separate parts it runs fine.
I’m thinking there is a hardware problem with my recent AC2. It also didn’t do anything out of the box: no wifi, not possible to connect to 192.168.88.1 via Eth2..5, no detection on WinBox via MAC or IP. I had to do a reset by holding the reset button during power-up, after that it looked ok as in default configuration.
Try to add pause of 2-3 seconds between importing each line
Is it possible to add a delay using the ‘import’ command?
