I have a 46 mile link in the 5900 MHz ham band crossing over the majority of the San Francisco peninsula… pretty challenging run. 3 foot dishes and NetMetal 5 units at each end.
The link is running very reliably, usually around 86 Mbps each way, occasionally higher, sometimes down lower.
But for my application, I really don’t need anywhere near that much bandwidth - but I am transporting some VoIP traffic - so I’d really like to avoid the long retransmit times that happen when the radio needs to downshift, often several steps.
So…
Can I lock in a lower set of AC rates?
Would I be better off switching to N and can I lock in a set of lower N rates with this hardware?
If not, is there some hardware that comes in as nice a box (or that I can swap into the NetMetal 5 box) that will allow locking in a subset of lower N rates?
Will we be getting the ability to narrow the channel (giving me a bit more margin as well) with this hardware?
I really like the ability to easily tune into the ham band, and the link is really much better than I imagined it would be, but the jitter caused by the retransmits is killing me here…
64 bytes from xxx: icmp_seq=71 ttl=62 time=4.65 ms
64 bytes from xxx: icmp_seq=72 ttl=62 time=5.70 ms
64 bytes from xxx: icmp_seq=73 ttl=62 time=17.9 ms
64 bytes from xxx: icmp_seq=74 ttl=62 time=9.86 ms
64 bytes from xxx: icmp_seq=75 ttl=62 time=3.69 ms
64 bytes from xxx: icmp_seq=76 ttl=62 time=3.60 ms
64 bytes from xxx: icmp_seq=77 ttl=62 time=5.59 ms
64 bytes from xxx: icmp_seq=78 ttl=62 time=15.5 ms
64 bytes from xxx: icmp_seq=79 ttl=62 time=4.74 ms
64 bytes from xxx: icmp_seq=80 ttl=62 time=4.34 ms
64 bytes from xxx: icmp_seq=81 ttl=62 time=11.8 ms
64 bytes from xxx: icmp_seq=82 ttl=62 time=845 ms
64 bytes from xxx: icmp_seq=83 ttl=62 time=5.99 ms
64 bytes from xxx: icmp_seq=84 ttl=62 time=15.5 ms
64 bytes from xxx: icmp_seq=85 ttl=62 time=5.10 ms
64 bytes from xxx: icmp_seq=86 ttl=62 time=4.37 ms
64 bytes from xxx: icmp_seq=87 ttl=62 time=3.78 ms
64 bytes from xxx: icmp_seq=88 ttl=62 time=11.1 ms
64 bytes from xxx: icmp_seq=89 ttl=62 time=1356 ms
64 bytes from xxx: icmp_seq=90 ttl=62 time=360 ms
64 bytes from xxx: icmp_seq=91 ttl=62 time=6.63 ms
64 bytes from xxx: icmp_seq=92 ttl=62 time=10.7 ms
rtt min/avg/max/mdev = 3.198/50.085/1359.801/203.294 ms,
