Can anyone please explain what “chain src-nat with action accept” does and what do they use it for.
The action=accept is used to exclude something from a specific rule. I used this recently. The example below excludes 192.168.0.2 from the redirect because it is a separate proxy server that you do not want going through the router’s transparent proxy. All other 192.168.0.x ips will go through the router’s proxy. edit: It is actually a dstnat, but the theory is the same.
add chain=dstnat action=accept src-address=192.168.0.2 dst-port=80 protocol=tcp
add chain=dstnat action=redirect src-address=192.168.0.0/24 dst-port=80 to-ports=8080 protocol=tcp
You can actually do similar tricks in all of the nat and mangle chains. Very useful.
Thanks SurferTim,
can you please explain the following configuration and what it does ![]()
add chain=src-nat action=accept src-address=192.168.1.0/24 dst-address=192.168.2.0/24
add chain=src-nat action=accept src-address=192.168.2.0/24 dst-address=192.168.1.0/24
these are two subnets on 2 different interfaces but same router .
Thanks ![]()
can you please explain the following configuration and what it does >
That keeps any srcnat rules from applying to those src and dst ip ranges. Normally the way I set up srcnats and masquerades, I don’t need those rules. However, if you have a rule like this, you would need that.
add chain=srcnat action=masquerade
If you used an out-interface on that rule, you wouldn’t need the accept rules.
