Initial config of CRS304-4XG-IN?
(Posts split from Is there a SwOS version compatible with CRS304-4XG-IN? - http://forum.mikrotik.com/t/is-there-a-swos-version-compatible-with-crs304-4xg-in/179925/1)
Hi all
i have this exact same problem! Its my first time buying a Mikrotik device and i start regretting it (please prove me wrong!!)
I just received this CRS304 10GB SWITCH (and i bought this exactly for that reason, using it as a SWITCH and needs it to be 10 GBE) and i spent all day yesterday trying to make this work as a dumb 10 GBE switch ( i dont need all routing features!). I tried also setting it to boot on SwOS but had the same issues as described here (booting loop). had to reset it about 12 times, and still can’t make this work! Why advertising this as a 10 GBE switch if it doesn’t work as a switch right out of the box? Please let me know what i am missing.
thanks
MT
I’m pretty sure that if you reset your CRS to defaults, it’ll come out configured as “dumb switch” even when running ROS. The only item to be done after that is to adjust IP address if you don’t like the one used by default. Shouldn’t be too hard when using Webfig (just try to avoid Quickset - switch over to Webfig … Quickset is very limited and has tendency to screw config if anything is done outside Quickset).
unfortunately, no, the out of the box config isnt working of rme..
Post config and specify what you want to do.
1 bridge
All interfaces to bridge
Possibly dhcp client to bridge or fixed ip.
There is not much more to it.
For config
open terminal
export file=anynameyouwish
move file to PC
redact serial number
post contents back here in between [__code] [/__code] quotes.
PS splitting this thread …
Hello everyone,
I have a setting question: I have the CRS304-4XG-IN directly connected to my router and powered by the supplied wall adaptor.
When I tried to power the switch with the 1Gb/POE connector by a POE switch which is on my LAN, the 10Gb switch internet connection stops.
I’vev been searching a specific setting but I’m a bit lost now. :grimacing:
Did I miss something ?
All help is more than welcome.
Thanks !
