Hello friends. I want to know if there are any way to insert an image (like a logo) and a title on maps.
Thanks!
You can do this with the “Static Network Element”.
Insert, right-click, select Appearance, select image (previously uploaded to the Dude), choose a proper scale for the image, select rectangle as shape and use white as color.
-Chris
Thank you so much. It´s works excellent. It was very helpful.
Hello everyone.. it´s me again with a same issue… we have to change device and after update firmware i cant upload images on dude… i copy image at dude/files, but it doesn´t appears on image´s list. Can someone do it? Thanks in advance for the time and help.
Make sure the filename extension is correct (and correct case) eg. “picturefile.jpg” is recognised by Dude as a picture but “picturefile.JPG” is not.
put images on /dude/files/images and mibs on /dude/files/mibs
do not put anything on /dude/files/default (/dude/files/default/images) because the default directory are destroyed and recreated from scratch at every boot
Very easy and simple, I agree. At first I didn’t figure it out myself, but then I mastered the interface and everything became intuitive.
