Inter-VLAN routing and internet access to VLANs
I have been running my mikrotik router for a while using the config generated by the QuickSet menu, and I am trying to create 3 VLANs, with a one sided inter-VLAN routing so that I can manage devices that are separated. I have an external switch (HP V1910-48G), connected to my router on port eth9 to port 48 on the switch. My 3 VLANs are created on the switch, with the ports 1-47 set to untagged/access, each set to their respective VLAN and port 48 is tagged/hybrid on each VLAN. I have also created my VLANs on my mikrotik router, the addresses, the DHCP servers and fortunately, the devices connected the ports on my switch get the adequate ip based on the VLAN associated. However, inter-VLAN routing does not work: I cannot access devices from 1 VLAN to another, no matter the VLAN. Another weird problem I have is that the devices on VLAN10 (home vlan) have no internet access, while the devices on VLAN 20 and 30 do. Here is my current config:
# apr/04/2025 23:45:06 by RouterOS 6.49.17
# software id = EADN-FEFS
# model = RB3011UiAS
# serial number = HEQ090099NM
add admin-mac=78:9A:18:0A:BB:D5 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=100M-half,100M-full,1000M-half,1000M-full
/interface vlan
add interface=bridge name="Home (VLAN 10)" vlan-id=10
add interface=bridge name="Server (VLAN 20)" vlan-id=20
add interface=bridge name="Wifi (VLAN 30)" vlan-id=30
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk mode=dynamic-keys name=WPA2 supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=Home ranges=192.168.10.10-192.168.10.200
add name=Server ranges=192.168.20.10-192.168.20.200
add name=Wifi ranges=192.168.30.10-192.168.30.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=Home disabled=no interface="Home (VLAN 10)" name=Home
add address-pool=Server disabled=no interface="Server (VLAN 20)" name=Server
add address-pool=Wifi disabled=no interface="Wifi (VLAN 30)" name=Wifi
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge interface=ether8
add interface="Home (VLAN 10)" list=LAN
add interface="Server (VLAN 20)" list=LAN
add interface="Wifi (VLAN 30)" list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.10.1/24 interface="Home (VLAN 10)" network=192.168.10.0
add address=192.168.20.1/24 interface="Server (VLAN 20)" network=192.168.20.0
add address=192.168.30.1/24 interface="Wifi (VLAN 30)" network=192.168.30.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
add address=192.168.30.0/24 gateway=192.168.30.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4,1.1.1.1
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=81 protocol=tcp to-addresses=192.168.20.11 to-ports=80
add action=dst-nat chain=dstnat dst-port=444 protocol=tcp to-addresses=192.168.20.11 to-ports=443
/system clock
set time-zone-name=America/Toronto
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
