inter-VLAN routing
Good day to everyone! Please, do not rail me. I’m novice in serious networking.
I have:
ASW1 and ASW3 - HP V1910-16G
ASW2 - HP ProCurve 1700-24
gw1 - Mikrotik 951G-2HnD.
I’ve made trunk (pass through only tagged frames) on switch port connected to GW1. Links between ASW1 ASW2 ASW3 are also trunks.
Like this manual tells i’ve created vlan interfaces
add name=VLAN51 vlan-id=51 interface=ether1 disabled=no
add name=VLAN52 vlan-id=52 interface=ether1 disabled=no
add name=VLAN53 vlan-id=53 interface=ether1 disabled=no
and then gave ip-addresses to vlans
add address=192.168.0.9/24 interface=VLAN51
add address=192.168.2.9/24 interface=VLAN52
add address=192.168.3.9/24 interface=VLAN53
in routes:
[admin@MikroTik] /ip route> print
 0 A S  0.0.0.0/0          192.168.0.9     192.168.0.133             1
 1 ADC  192.168.0.0/24     192.168.0.9     vlan51                    0
 2 ADC  192.168.2.0/24     192.168.2.9     vlan52                    0
 3 ADC  192.168.3.0/24     192.168.3.9     vlan53                    0
I’ve connecting my PC to “access” port on ASW2 belongs to VLAN 52 and in PC network adapter properties have pointing address from VLAN52 subnet and 192.168.2.9 as a gateway. But when I have try to ping address belongs to VLAN 51 I’ve got inaccessibility of that address. I’ve trying to add static route on my PC for VLAN 51 addresses as destination through 192.168.2.9 gateway, but also gave nothing.
Can anyone kick me in the right direction?
Post your full config… also the clients all have default gateways set?
Oops!
mikrotik config
/interface> print
 #     NAME                             TYPE               MTU L2MTU  MAX-L2MTU
 0  R  ether1                           ether             1500  1598       4074
 1     ether2                           ether             1500  1598       4074
 2     ether3                           ether             1500  1598       4074
 3     ether4                           ether             1500  1598       4074
 4     ether5                           ether             1500  1598       4074
 5  X  wlan1                            wlan              1500
 6  X  bridge-local                     bridge            1500
 7  R  vlan51                           vlan              1500  1594
 8  R  vlan52                           vlan              1500  1594
 9  R  vlan53                           vlan              1500  1594
10  X  ether_vlan_br                    bridge            1500
/ip address> print
 #   ADDRESS            NETWORK         INTERFACE
 0 I ;;; default configuration
     192.168.88.1/24    192.168.88.0    bridge-local
 1   192.168.0.9/24     192.168.0.0     vlan51
 2   192.168.2.9/24     192.168.2.0     vlan52
 3   192.168.3.9/24     192.168.3.0     vlan53
Client PC connected to access port (VLAN52) on ASW2 switch and have settings:
Description  . . . . . . . . . . . . : Intel 8255x-based Ethernet 10/100 PCI adapter
        Physical address. . . . . . . . . : 00-E0-00-17-E4-AC
        Dhcp enabled. . . . . . . . . . . : no
        IP-address  . . . . . . . . . . . . : 192.168.2.3
        Network mask . . . . . . . . . . : 255.255.255.0
        Default gateway . . . . . . . . . . : 192.168.2.9
ping test from Mikrotik CLI passes to all subnets connected to all of described above switches.
[admin@MikroTik] > ping 192.168.2.3
HOST                                     SIZE TTL TIME  STATUS
192.168.2.3                                56 128 0ms
    sent=8 received=8 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
[admin@MikroTik] > ping 192.168.3.1
192.168.3.1                                56 255 10ms
192.168.3.1                                56 255 1ms
    sent=4 received=4 packet-loss=0% min-rtt=1ms avg-rtt=3ms max-rtt=10ms
[admin@MikroTik] > ping 192.168.0.100
192.168.0.100                              56 128 0ms
    sent=5 received=5 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
No, other clients have different gateway address. Does it matter?
Do you have proper forward rules accepting traffic (including icmp) between vlan interfaces?
Something like accept forwarding with src=192.168.0.0/16 dest=192.168.0.0/16…
Only those that were by default.
[admin@MikroTik] /ip firewall filter> print
 0   ;;; default configuration
     chain=input action=accept protocol=icmp
 1   ;;; default configuration
     chain=input action=accept connection-state=established
 2   ;;; default configuration
     chain=input action=accept connection-state=related
 3   ;;; default configuration
     chain=input action=accept in-interface=ether1
 4   ;;; default configuration
     chain=forward action=accept connection-state=established
 5   ;;; default configuration
     chain=forward action=accept connection-state=related
 6   ;;; default configuration
     chain=forward action=drop connection-state=invalid
That’s why it is not working. Each vlan interface is a interface in its own rights.
There are no established/related connections if you initialize a connection on your vlans so nothing will be forwarded.
Try adding such a forward rule as described.
Yes, it really works.
I’ve add these rules and packets start to pass between VLANs.
 7   chain=forward action=accept protocol=icmp src-address=192.168.0.0/16
     dst-address=192.168.0.0/16
 8   chain=forward action=accept protocol=tcp src-address=192.168.0.0/16
 9   chain=forward action=accept protocol=udp src-address=192.168.0.0/16
Thank you!
If those are the only vlans you plan to use its even simpler:
add chain=forward action=accept in-interface=all-vlan out-interface=all-vlan
It seems that i must go to read manual. Thanks, I will try it.
Why to use vlans if everything has to pass everywhere?
Sent from Android by Tapatalk.
Actually i added same but icmp not working in vlan
Rajesh
Very good point!
maybe broadcast traffic reduction if there are many hosts
