Interface Ip Assign
Greetings
I assigned the following Ip address 10.20.0.4 to interface 8
I want to assign this ip address to a computer that im connecting to this interface
what needs to be accomplished to do this?
Just do it according the ip setting procedure from the manual to the operating system you are running on the computer. You were not informed us why you want to do so and what should be the effect. Assigning only the ip doesn’t do anything on its own.
Ok so you have 10.20.0.4 on a interface and you want to assign 10.20.0.4 to a computer plugged into that interface?
What are you trying to accomplish here?
We need a bit more info on this
Thanks for all the help guys!
I will connect a Access Point in the interface 8 and i want to assign the same ip address (NAT/BRIDGE)??
I also want to relay DHCP Services i already created DHCP Pool and assigned it to that interface so WIFI Clients
get ip addresses from the pool…
It’s usual to assign a different ip address if you want it to work. Normally. Otherwise your request is a bit strange so we don’t understand it…
If you want to extend a network via bridge, there is no need of ip to be assigned to bridging device or to make any dhcp relay.
