I’m trying to figure out my internet consumption and have forgotten to enable graphs.
looking at the Ethernet interface stats I see total RX/TX, but I’m not sure when that’s reset.
my modem (linked via ethernet port to my MT) restarts each night, so the link goes down every 24h, but the MT interface/device stays up all the time. So, the TX/RX stats are reset upon link up/down or upon router restart?
No, interface counters are only reset on reboot. And they cannot be reset manually.
Only when you have a dynamic interface that would be removed when the link is down, e.g. an L2TP client, it would be reset.
The button “Reset Counters” on ethernet interface is only for reset Overall Stat / RX Stat / TX Stat (when is supported on the model)
not for Status (link down) or Traffic (Bytes/Packets/Drops).
And YES, on the first times I use that button, I’m expecting that reset all counters, traffic and drops included, but I have learn that is not work on that way…
