Internal speed problem width CCR1036
I have a problem width ccr1036-8G-2S SFP+ router .
The router has a 10GB sfp+ in the 1-sfp+ slot . The link is on 10 Gb is linked .
When i bridge the SFP+ 1 and 2 ports and install a another 10 GB DAC in to the second sfp+ port , i make 2 Gbs load in from over the SFP+ 1 and out on the SFP+ 2 to the test equipment .
But if the incoming bandwith use in the router i never load over 1 Gbs . If the incoming bandwith over 1 Gbs the router accesible is very hard or innacessible from outside ( not have free bandwitdh ) .
And if i send examle 1300 Mbit load to the router from outside the router only sign 998 Mbit on the port .
The router get the load from 3 vlan , the vlans is coming in on the SFP+ 1 .
Why not load the router over 1 Gbps …
