i have a very simple configuration.
so quick set ether1 WAN DHCP from isp , ether2-5 LAN with ip 192.168.88.1
DHCP 2-100
some devices in LAN have DHCP ip , other static ip with 192.168.88.0/24.
can i setup a netmap or other function (ex dstnat o srcnat) to call my devices with another class?
example to print i setup printer on my server with ip 192.168.88.5
but i would setup with 192.168.89.5
and for all other devices i would when i call 192.168.89.0/24 respond 192.168.88.0/24 in transparent mode, without config every device.
Yes, action=netmap rules in chains src-nat and dst-nat of /ip firewall nat do exactly this. Just bear in mind that if you want “transparent” traffic, i.e. that connections could be established in either direction, you must have the appropriate rule in both chains, as it is still a NAT handling, i.e. it is assigned to a connection when the firewall handles its very first packet.
You may want to restrict those rules only to traffic incoming or outgoing via a particular interface or from/to a particular remote address (or address range, or address list), but yes, the baseline rules are these.
