Hi - I’m pretty new to Mikrotik, and spent quite a lot of time playing and researching this week. I’ve learned some stuff, but am stuck on a few bits.
The plan is to receive the wifi broadcast from my Starlink router with my MT C53UiG+5HPaxD2HPaxD ax3 device. I then wanted other devices connected to the MT by ethernet (my homelab servers) to be seen on the Starlink LAN via wifi so I can access them locally. I also want those devices to have access to the internet.
At the moment I have got the setup so the MT device connects to my Starlink via wifi, however, the devices on the MT LAN Bridge cant see the internet, though I can ping google.com from the MT terminal.
I’m using the GUI more than the CLI. What am I missing?
# 2024-01-19 21:23:26 by RouterOS 7.13.2
# software id = TFIP-T5R2
# model = C53UiG+5HPaxD2HPaxD
# serial number = HF309EC74SC
add name=LAN-Bridge port-cost-mode=short
add name=Wifi-Bridge port-cost-mode=short
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=FPHQ
/interface wifi
set [ find default-name=wifi1 ] configuration.country="United Kingdom" .mode=\
station .ssid=FatParamotorHQ disabled=no security=FPHQ
set [ find default-name=wifi2 ] configuration.country="United Kingdom" .mode=\
station-bridge .ssid=FatParamotorHQ disabled=no security=FPHQ
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool2 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool3 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool4 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool5 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool6 ranges=192.168.1.2-192.168.1.254
add add-arp=yes address-pool=dhcp_pool6 interface=LAN-Bridge name=dhcp1
add bridge=LAN-Bridge fast-leave=yes interface=ether1 internal-path-cost=10 \
path-cost=10 trusted=yes
add bridge=LAN-Bridge fast-leave=yes interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=LAN-Bridge interface=ether3 internal-path-cost=10 path-cost=10
add bridge=LAN-Bridge interface=ether4 internal-path-cost=10 path-cost=10
add bridge=LAN-Bridge interface=ether5 internal-path-cost=10 path-cost=10
add bridge=LAN-Bridge fast-leave=yes interface=*B internal-path-cost=10 \
add bridge=Wifi-Bridge interface=wifi1 internal-path-cost=10 path-cost=10 \
trusted=yes
add bridge=Wifi-Bridge interface=wifi2 trusted=yes
add interface=Wifi-Bridge list=WAN
add interface=LAN-Bridge list=LAN
add address=192.168.1.3/24 interface=LAN-Bridge network=192.168.1.0
add address=192.168.1.4 disabled=yes interface=Wifi-Bridge network=\
192.168.1.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.11 client-id=1:bc:24:11:52:fe:92 mac-address=\
BC:24:11:52:FE:92 server=dhcp1
add address=192.168.1.0/24 dns-none=yes gateway=192.168.1.1
set allow-remote-requests=yes
add action=masquerade chain=srcnat out-interface=Wifi-Bridge
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
I’ve run into a dead end so tried a different approach.
I set up the MT in default settings to give a default wifi signal to connect to my router.
In this configuration the internet would come into the WAN eth1 connection.
I set the second wifi radio wifi2 to station and connected it to my existing starlink wifi to get internet access SSID=“FatParamotorHQ”. I added this device to the WAN list.
When I connect my laptop to the MT wifi (wifi1) SSID=“Homelab” I get a similar problem - it sees no internet. The devices connected to the MT router by ethernet see no internet.
In the MT terminal I can ping google with no problems.
How can I configure the NT so the ethernet ports and the wifi1 can see the internet coming via wifi2?
Many thanks … Shaun
# 2024-01-20 17:29:12 by RouterOS 7.13.2
add admin-mac=78:9A:18:62:FE:9B auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=station .ssid=FatParamotorHQ \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
.ft-over-ds=yes
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=Homelab \
disabled=no security=FPHQ security.authentication-types=wpa2-psk,wpa3-psk \
.ft=yes .ft-over-ds=yes
add name=pool-homelab ranges=192.168.1.10-192.168.1.254
add name=dhcp_pool3 ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp_pool3 interface=bridge name=dhcp1
add bridge=bridge broadcast-flood=no interface=wifi1
/interface detect-internet
set wan-interface-list=all
add interface=wifi2 list=WAN
add address=192.168.1.131 comment=defconf interface=bridge network=\
192.168.1.0
/ip dhcp-client
add comment=defconf interface=wifi2
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system note
/tool mac-server
/tool mac-server mac-winbox
jaclaz
January 21, 2024, 12:09pm
3
I seem like not seeing any route?
What is the output of
/ip route print
rplant
January 22, 2024, 10:51am
4
Using your second config
From memory, the starlink will be handing out 192.168.1.x IP addresses, so without some fiddling
you can’t have a 192.168.1.x address on the Mikrotik’s bridge, for this mode of operation.
192.168.1.0
Indicates a /32 network.
(Except change .1.x to most anything else I am going to use .2.x)
You will want something like
add address=192.168.2.131/24 comment=defconf interface=bridge network=
192.168.2.0
Then in the dhcp network section and pool, you should change the settings to point at the mikrotik bridge
add address=192.168.2.0/24 dns-none=yes gateway=192.168.2.131
and similarly with the pool.
One other option, (that with luck might work)
They have implemented very recently station pseudo bridge for the new wifi,
This may allow you to bridge from the mikrotik to the starlink.
(In which case you can have a .1.x ip address on the bridge, but dhcp is sent from the starlink)
Turn off rstp on the mikrotik bridge, it seems to cause issues in this mode.
