Internet slow with Mikrotik router
Hi, beginner with Mikrotik here.
Borrowing from Internet I got my RB4011iGS working. Port ether1 is for connection to the ISP. It configured using vlan2 and vlan4. If I got it right.
It works all right, but instead of the high speed from the fiber connection to the ISP is sticks at 20 mbps.
The Mikrotik replaces a Fritzbox router provided by the ISP. The Fritzbox does show the high speeds I expect.
If I play around with the settings in the Mikrotik sometimes the speed is ok in a first speedtest, but when I repeat it it is slow. And remains slow.
I configured ether2 on the Mikrotik to connect to the Fritzbox and then the speed is ok. So the Mkrotik’s inherent speed is not the problem.
Can anyone on the forum shed some light on what I maight have done wrong?
The configuration file is attached to this message.
Any help would be greatly welcomed!
ConfigRob.rsc (3.26 KB)
Is this a requirement from your ISP? That is, do you need to “join” these two VLANs from your ISP in order to get Internet access?
If so, then you should only be using the VLAN virtual interfaces, not the physical interfaces.
You gutted the default configuration, is what you did. Compare the stock version to see how far you’ve strayed.
If I were you, I’d take the new configuration as a guide to work from, then reset to the stock configuration and reapply the minimal set of changes to get it working. Then, back up your now-working configuration and apply the rest of your changes one by one, testing at each change. Update the backup on each successful test, rollback on each failure.
Also, some broad advice: don’t rip all the IPv6 stuff out. Instead, get it working properly. The time for ignoring IPv6’s existence is long past.
Thanks for your prompt answer!
It is not a requirement from the ISP is not to join the vlans. According to them
vlan2 is for internet
vlan4 is for tv
vlan6 is for phone. I don’t use that.
However, when I first got it working, the signal came through vlan4. Don’t know what made vlan2 to work as well.
Apart from making configuration as similar to default (as suggested by @tangent) … I’d start by
  • removing DHCP client from anything but vlan2 interface. If your router manages to obtain DHCP lease on more than one interface, it may get lost as to which default route it should use.
  • removing vlan4 interface … you very likely don’t want to route IPTV traffic (you may want to switch it to IPTV set-top boxes, but if this is the case, you’ll have to approach L2 setup quite a bit differently than you have it now)
  • adding vlan2 interface to WAN interface list … this should make firewall and NAT rules work as intended without butchering all the firewall config
firewall rules also need to be fixed because there is a big mix there. Not the correct roll order, etc. As an example:
add name=WAN
add name=LAN
add interface=ether1 list=WAN  (replace as needed)
add interface=bridge1 list=LAN (replace as needed)
established,related,untracked
invalid
    "Allow access to router from known network" in-interface-list=LAN \
    src-address-list=LAN_List
add action=drop chain=input comment="Drop all else"
connection-state=invalid
add action=accept chain=forward comment="internet" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
Thanks guys, I got the speed all right now.
The tips from @mkx did the trick.
I will follow the advice of @Tangent and @johnson73 to get a more decent configuration, especially of the firewall.
I am having a similar problem. I am new to Mikrotik so I would appreciate some guidance on my config. I did enable Fast Path which improved speed a little, but i am still only at about 40% of my ISP speed. With FastTrack disabled I am at about 25%. When I set the router to be in Bridged mode, I get 100% of the speed. Let me know if you need any more detail and thanks in advance for your help here!
SFP 1 is my ISP Fiber ONT
SFP 2 and 3 are used.
SFP 4-7 are not used.
SPF8 is a wireless access point.
# aug/03/2025 19:48:32 by RouterOS 6.49.19
# software id = D6B7-USIA
# model = CRS309-1G-8S+
# serial number = ###########
add admin-mac=##:##:##:##:##:## auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp-sfpplus1 ] advertise=2500M-full
set [ find default-name=sfp-sfpplus2 ] advertise=10000M-full
set [ find default-name=sfp-sfpplus3 ] advertise=1000M-half,1000M-full
set [ find default-name=sfp-sfpplus4 ] advertise="10M-half,10M-full,100M-half,\
    100M-full,1000M-half,1000M-full,2500M-full,5000M-full,10000M-full"
set [ find default-name=sfp-sfpplus5 ] advertise="10M-half,10M-full,100M-half,\
set [ find default-name=sfp-sfpplus6 ] advertise="10M-half,10M-full,100M-half,\
set [ find default-name=sfp-sfpplus7 ] advertise="10M-half,10M-full,100M-half,\
set [ find default-name=sfp-sfpplus8 ] advertise=2500M-full
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.88.2-192.168.88.200
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
add bridge=bridge comment=defconf interface=sfp-sfpplus3
add bridge=bridge comment=defconf interface=sfp-sfpplus4
add bridge=bridge comment=defconf interface=sfp-sfpplus5
add bridge=bridge comment=defconf interface=sfp-sfpplus6
add bridge=bridge comment=defconf interface=sfp-sfpplus7
add bridge=bridge comment=defconf interface=sfp-sfpplus8
/ip settings
set allow-fast-path=no
add interface=sfp-sfpplus1 list=WAN
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
/ip dhcp-client
add disabled=no interface=sfp-sfpplus1
/ip dhcp-server lease
add address=192.168.88.2 client-id=1:a0:36:9e:15:81:ed mac-address=\
    A0:36:9E:15:81:ED server=dhcp1
add address=192.168.88.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.88.1 \
    netmask=24
set allow-remote-requests=yes
add action=fasttrack-connection chain=forward connection-state=\
    established,related
add action=accept chain=forward connection-state=established,related
add action=accept chain=input in-interface-list=LAN src-address=\
    192.168.88.0/24
add action=drop chain=input in-interface-list=!LAN
    established,related
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu protocol=tcp \
    tcp-flags=syn
    tcp-flags=syn
/ip service
set telnet disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=America/New_York
/system routerboard settings
set boot-os=router-os
No, you don’t, CRS309 is a network switch, not a router.
It is a switch but can use RouterOS or SwitchOS. Seems like it can be either?
Yes, but a switch at first.
It CAN route, but it’s not really good at it.
What do you see as throughput ?
I would expect somewhere from 300 - 500 mbps max.
Yes, that is about right. The max i got was ~700Mbs. My ISP is 2Gb. When in bridge mode i get 2.3Gb. I need a switch anyway so if CRS309-1G-8S+ can’t handle it, then i think i will get CCR2004-1G-12S+2XS for the routing function.
The CRS309 can do L3 offload with NAT, so it can handle it if you can stay within the limits of its capabilities: L3 Hardware Offloading - RouterOS - MikroTik Documentation
