Invalid DHCP server
I’m trying to setup a dhcp server on wlan0 of my Metal 52ac, but for some reason the server settings I have are invalid:
[admin@MikroTik] /ip dhcp-server> print
Flags: D - dynamic, X - disabled, I - invalid
 #    NAME              INTERFACE            RELAY           ADDRESS-POOL            LEASE-TIME ADD-ARP
 0  X defconf           wlan1                                default-dhcp            10m
 1  I server1           wlan1                                default-dhcp            10m
I can’t find any solutions to this from searching; my best guess is that it might be something to do with the IP pool?
Here is my ip config:
# jan/21/2019 17:03:17 by RouterOS 6.43.8
# software id = 1K4A-AQNN
# model = Metal G-52SHPacn
# serial number = A80809E0DBD5
/ip hotspot profile
add name=default-dhcp ranges=192.168.1.101-192.168.1.250
add address-pool=default-dhcp interface=wlan1 name=defconf
add address-pool=default-dhcp disabled=no interface=wlan1 name=server1
add address=192.168.1.3/24 comment=sph interface=ether1 network=192.168.1.0
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1
set allow-remote-requests=yes servers=192.168.1.1
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add distance=1 gateway=192.168.1.1
/ip smb
set domain=WORKGROUP
You have assigned the address 192.168.1.3 to ether1 and no address to wlan1.
If you want to bridge ether1 and wlan1 so they are the same layer2 network then both interfaces should be added to a bridge, the IP address and DHCP server should specify the bridge as the interface, not any of the members. N.B. the DHCP server will serve any requests from both ether1 and wlan1 interfaces.
If you want to route traffic between ether1 and wlan1 then add IP addresses in different subnets to both interfaces, check the DHCP server, network and IP pool addresses are in the same subnet as the address on wlan1.
It didn’t occur to me that every interface need to have an ip address assigned. In my mind I only needed one to target the device (routeros) but the other one was just like a port on a switch, which don’t usually have their own addresses.
So I added an address to wlan0 and that seems to have got the dhcp server working properly. For now, I only want it assigned to wlan, rather than bridge, as there is another dhcp server on the eth side on my current network.
However, when I enable the bridge I still have the same problem I mentioned in another thread – that I loose all access to the router, via webfig or ssh. So I can no longer make any changes without doing a hard reset and starting again… I tried assigned an ip address to the bridge interface as well, but that didn’t seem to help. Any ideas?
You need IP address on all interfaces which take part in L3 (IP) communication. DHCP address assignment is an IP communication, hence DHCP server needs IP address in the interface where DHCP server is running. In addition to that, your RB is right now acting as a router between wired and wireless LANs and for that it clearly needs IP addresses on both involved interfaces.
So you would like to actually make ethernet and wifi interfaces part of same LAN, sharing same IP address space? Post your complete configuration (/export hide-sensitive) and we might get some idea …
This is my current setup. DHCP server is working on the wlan side ok. However, as soon as I enable the bridge, wireless clients can access the lan side (so the bridge is working), but the router ceases to be available over network via any port (a port scan shows nothing open) so the webfig and ssh connections, and ping, all die.
It’s anecdotal, but I have had the router disappear like this a lot over the last few days, and not just when I enable a bridge. Sometime it has been when updating various simple settings, that don’t make any major change to things, but suddenly all is lot. Sometimes, if I reboot the metal then I can access it again, but other times I need to do a hard reset and reload my last working config. Sadly, rebooting with the bridge enabled does not make the router accessible again.
# jan/02/1970 00:02:32 by RouterOS 6.43.8
add disabled=yes fast-forward=no name=bridge1
set [ find default-name=ether1 ] speed=100Mbps
add comment=defconf name=LAN
add authentication-types=wpa2-psk management-protection=allowed mode=dynamic-keys name=blue_planet \
    supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no \
    frequency=auto mode=ap-bridge security-profile=blue_planet ssid="Video World"
/ip hotspot profile
add name=default-dhcp ranges=192.168.1.101-192.168.1.199
add bridge=bridge1 interface=wlan1
add comment=defconf interface=ether1 list=LAN
add interface=wlan1 list=LAN
add address=192.168.1.4/24 interface=wlan1 network=192.168.1.0
add address=192.168.1.9/24 interface=bridge1 network=192.168.1.0
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=192.168.1.1
/ip dns static
add address=192.168.1.1 name=router.lan
    established,related
    connection-nat-state=!dstnat connection-state=new in-interface-list=*2000010
/system leds
set 1 leds=led2,led3,led4,led5
add interface=wlan1 leds=led1 type=interface-activity
/tool mac-server
/tool mac-server mac-winbox
Inaccessibility of your RB right after you enable bridge is caused by FW rule
Because suddenly firewall sees incoming packets not from ether1 but from bridge1. The very same omission breaks MAC WinBox access as well:
Cure is to add bridge1 to appropriate interface list before enabling bridge again:
Next time, before trying to enable bridge again, enable safe mode (I’ve heard that there exists an icon somewhere in NE corner of Winbox app … using CLI, CTRL-X toggles it) and in case that change really breaks connectivity of current management session, changes will get reverted after 10 or 20 seconds.
After you successfully enable bridge, you’ll have to re-work L3 configuration of your RB.
Success!
That was the missing piece of the puzzle. Thank you for spotting it.
My only other question, for now, is do I still need to assign an ip address to all of eth0, wlan0 and bridge1?
If the role of this device is bridge between wireless and wired LAN, then the only reason to keep IP address is for management access. If you plan to use Winbox for management, IP setup is not needed even for that as you can use MAC connection.
If you decide to keep IP address, bind it to bridge1 (wlan and ether ports don’t need their own IP addresses). You might want to add a default route with your main router as gateway … so you can perform ROS upgrades etc.
Brilliant, thanks. I’d not noticed the route was missing; it must have got unset during one of my many resets… :-/
