IOT devices over wireless - DHCP assigns and deassigned
I have a RB5009 setup as my main router with a DHCP server enabled. The lease time is set to 3 days. I have ethernet ports 1-8 bridged and my SFP+ port is used as my WAN connection to my ISP. I turned my old asus router into an access point for now and turned off DHCP server and router functions. This serves as my wireless access to my laptop, desktops, IOT devices, etc.
Almost all devices connect wirelessly without a problem. I have a device such as my controller to a sprinkler system that connects over wifi. I see the DHCP server lease an IP address to my controller but it does not last for more than 2 minutes. My log shows the device gets assigned an IP and then de-assigned less than a minute or two. Once de-assigned, its gets reassigned immediately. I initially thought it was isolated to one device, but now I see (2) thermostats that show the same pattern. Any thoughts?
Log from sprinkler controller:
Thermostat:
# 2024-01-29 22:24:00 by RouterOS 7.13
# software id = CYUY-IY5X
# model = RB5009UPr+S+
# serial number = XXXXXXX
add name=local
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp interface=local lease-time=3d name=dhcp1
add bridge=local interface=ether1
add bridge=local interface=ether2
add bridge=local interface=ether3
add bridge=local interface=ether4
add bridge=local interface=ether5
add bridge=local interface=ether6
add bridge=local interface=ether7
add bridge=local interface=ether8
set discover-interface-list=none
add interface=sfp-sfpplus1 list=WAN
add interface=wireguard1 list=LAN
add interface=local list=LAN
/interface wireguard peers
add allowed-address=192.168.100.2/32 interface=wireguard1 public-key="XXXXXXXXXXXXXXXXXXXXXXXXX1="
add allowed-address=192.168.100.3/32 interface=wireguard1 public-key="XXXXXXXXXXXXXXXXXXXXXXXxX2="
add address=192.168.0.1/24 interface=local network=192.168.0.0
add address=192.168.100.1/24 interface=wireguard1 network=192.168.100.0
/ip cloud
set update-time=no
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.0/24 dns-server=198.168.0.1,1.1.1.1,8.8.8.8,8.8.8.4 gateway=192.168.0.1
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes log=yes protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="WG handshake" dst-port=13231 log=yes protocol=udp
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="Remote to LAN" in-interface=wireguard1 out-interface-list=LAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat disabled=yes
add action=drop chain=forward comment="drop all else"
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.0/24,192.168.100.0/24
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.0.0/24
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=America/Chicago
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/user settings
set minimum-password-length=8
having the same issue.
IoT devices are disconnecting intermittently. Wifi signal is pretty strong.
Running an RB5009 on 7.14 and two cap AC`s with Capsman in forwarding mode.
This leads to issues within my Home Assistant instance :frowning:
Have enabled DHCP logs now, to see if something is wrong with the devices itself. Any ideas where to look?
Edit: Found already out, that my Reolink camera sends DHCP requests every 5 minutes (even with a wrong ip address) to check if wifi connection is good…
https://community.reolink.com/topic/1514/rlc-410w-with-latest-fw-continues-to-send-dhcp-requests-with-static-ip-config lol.
Maybe, this can help you:
http://forum.mikrotik.com/t/dhcp-deassigned-assigned-log-message-vlan-switch-rb3011/174156/1
