how can I overwrite the factory default device ID with /iot modbus ?
For experimentation purposes, I acquired a cheap temperature and humidity sensor. I’m able to read all of its values without issue. However, in order to use more than one device simultaneously, I need to modify the default ID on the second sensor. Unfortunately, I haven’t been successful in doing so.
I tried follow the instructions from here, but I was not able to set the default device ID from 1 to 2 ![]()
I’m sure I’m missing something, but after trying so many variations, I figured it’s better to just ask. ![]()
/iot modbus transceive address=0x01 function=0x03 values=0x00,0x00,0x00,0x02
address: 1
function: 3
data: 010304021100F4
values: 529
244
time: 2025-05-31 19:59:57
status: ok
/iot modbus transceive address=0x01 function=0x06 values=0,1,0,2
address: 1
function: 6
data: 010600010002
values: 1
0
2
time: 2025-05-31 20:07:12
status: ok
address: 1
function: 3
data: 010304020E00F5
values: 526
245
time: 2025-05-31 20:14:25
status: ok
/iot modbus transceive address=0x02 function=0x03 values=0x00,0x00,0x00,0x02
failure: Timeout
SHT30_sensor_datasheet.pdf (605 KB)
