When having IOT package on your router and export the config, you will see the MQTT password.
That should be only shown when doing an export show-sensitive
So MT please fix.
So MT please fix.
Did made also a ticket with support or did you just put it up here? ![]()
SUP-151732
It will be fixed ![]()
Our bug tracker reports, that your issue has been fixed. This means that in the upcoming days, we plan to release a RouterOS update with this fix.
