I’m using a MT 450 OS v4.5(?) connected to 2 ISP.
I have 2 public IP’s on different subnets for primary ISP and BackUp.
I’m running a dial-up VPN server on the MT.
However the PPTP server is being bound only to backup ISP’s IP.
So if I try to connect to backup ISP’s IP get a successful VPN connection. I’m able to browse into the network successfully and all. But if I try to do PPTP to primary ISP’s IP there is no connection.
Is there any way to bind the PPTP server to IP2 instead of IP1?
But the strangest thing is:
i removed whole ip configuration and disable Backup Interface.
As result only one outside int left and only 0.0.0.0/0 d=1 route left to outside.
Router has restarted, but I’m still unable to create pptp connection to my router.
Where is no fw filters enabled.
