I have bunch of vlans ‘under’ eth4 port. The eth4 port dont have any IP assigned, the vlans do have, IPs and DHCP servers.
Can I assign IP and dhcp server to the eth4 interface ? will that ‘shadow’ the vlan IPS ? will that disable vlans ?
If I assign IP to eth4 and connect a computer through cable, will the port act as standard eth4 interface ?
It will act as normal port, but also depend on the way you configured the Vlan’s.
The only thing is that if you have multiple vlan’s, the interface is acting as a trunk. Connecting a computer directly makes no sense, except for the fact that it will be temporarily.
I thought that connecting a computer to eth4 port (diagnostics setup puprose) the untagged packets from the computer would land onto eth4 interface instead of vlans.
My config has 24 vlans on eth12-port.
eth12-port has dhcp-server (192.168.200.0/24)
vlan01 has dhcp-server (192.168.201.0/24)
vlan02 has dhcp-server (192.168.202.0/24)
vlan24 has dhcp-server (192.168.224.0/24)
@bingo, I see you have a DGS, I have an issue with my DGS-1210-52, The DHCP traffic on vlans (except vlan1) is blocked unless I put dhcp server IP into “DHCP server screening” list. However there list is limited to 5 dhcp server hosts and I have more vlans. Did you experience anythink like that ?
