Hi Guys , Can I Change A Special User IP in Every Second? If yes How?
I Appriciate If Here is a Good Answer
It would help to know what and how you’re determining they’re changing IP addresses; for example the wireless registration table that shows a “last ip” which often reports back the most recent external IP passing traffic in that’s been seen, so could show a number of IP addresses in a short period.
Alternatively if they have a virus, or if there’s a DHCP bug refusing to allow a machine to pick up IP leases it is possible you would see multiple IP addresses via an end users connection.
More information about what you’re seeing is the best way to help us give a correct answer to your question. ![]()
Dear Thanks for your Reply, I am new to mikrotik, I want To find A IP Rotating Way in mikrotik for hotspot users , So can i use a type of Script or Firewall Rule in Mikrotik Which Will change the proxy or ip every second? I want The Mikrotik To Work Like a Proxy Changer or Ip , Not the Dhcp , I am Asking for Changing the Wan IP or parent Proxy every sec or every 5 sec in Mikrotik
Regards,
Sorry If there is a mistake in my english
Sure, you can make a script to change the IP every 5 seconds… but I don’t think your clients will be able to keep up with it!
How will your clients know what the new IP address is every 5 seconds???
