thank you for the fast reply,
I find out got some DNS resolve error before the fetch error,
it seems likt it redirect to other domain,
but the DNS resolve is not work
I try to able DNS resolve for router use the same DNS server as my PC using,
here a the dns status, I didn’t able to find any error
may I able to get you help for this issue?
[admin@MikroTik] /ip/dns> print
servers: 1.1.1.1
8.8.8.8
dynamic-servers:
use-doh-server:
verify-doh-cert: no
doh-max-server-connections: 5
doh-max-concurrent-queries: 50
doh-timeout: 5s
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
max-concurrent-queries: 100
max-concurrent-tcp-sessions: 20
cache-size: 2048KiB
cache-max-ttl: 1w
address-list-extra-time: 0s
vrf: main
mdns-repeat-ifaces:
cache-used: 68KiB
/export compact hide-sensitive
here are my config
# 2025-05-05 00:00:14 by RouterOS 7.18.2
# software id = HKJ2-B1GR
# model = RB5009UG+S+
# serial number = HEH08
add admin-mac= auto-mac=no comment=defconf dhcp-snooping=yes \
name=bridge port-cost-mode=short
/interface wireguard
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.8.10-192.168.8.254
add name=wifi ranges=192.168.20.100-192.168.20.200
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add address-pool=wifi interface=ether8 lease-time=5h name=wifiDHCP
/ip smb users
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10 trusted=yes
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
set discover-interface-list=LAN lldp-med-net-policy-vlan=1
/interface detect-internet
set detect-interface-list=all
add interface=ether8 list=LAN
add interface=vpn list=LAN
/interface ovpn-server server
/interface wireguard peers
add address=192.168.8.1/24 comment=defconf interface=bridge network=192.168.8.0
add address=192.168.20.1/24 interface=ether8 network=192.168.20.0
add address=192.168.11.1/24 interface=vpn network=192.168.11.0
/ip cloud
set ddns-update-interval=5m
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
add address=10.120.8.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 gateway=\
10.120.8.1 netmask=24
add address=192.168.20.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.20.1 \
netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.8.1 address-list=192.168.8.0/24 comment=defconf name=\
router.lan type=A
add address=192.168.20.1 address-list=192.168.20.0/24 name=wifihost type=A
add address=223.255.185.3 name=stdtime.gov.hk type=A
add address=159.148.172.251 name=cloud2.mikrotik.com type=A
add address=159.148.147.229 name=cloud.mikrotik.com type=A
add address=158.247.7.204 disabled=yes name=dynupdate.no-ip.com type=A
add address=159.148.172.226 name=upgrade.mikrotik.com type=A
/ip firewall address-list
add address=192.168.11.0/24 list=vpn_list
established,related,untracked disabled=yes in-interface-list=WAN protocol=\
icmp
add action=drop chain=forward disabled=yes dst-port=80,22,443,8291 \
in-interface=ether1 protocol=tcp
add action=accept chain=input protocol=udp src-port=53
add action=accept chain=input dst-port=53 protocol=udp
invalid
add action=accept chain=forward disabled=yes in-interface-list=LAN \
out-interface-list=WAN
add action=accept chain=input dst-port=13355 in-interface=ether1 protocol=udp
add action=accept chain=output comment="Allow HTTP traffic" dst-port=80 \
protocol=tcp
add action=drop chain=forward out-interface-list=WAN src-address-list=\
"server"
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall service-port
set sip disabled=yes
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
/snmp
set enabled=yes
/system clock
set time-zone-name=Asia/Hong_Kong
/system logging
add topics=dns
add topics=fetch
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=stdtime.gov.hk
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
