IP Firewall Filter rule not working with Bridge Mode
Hi Experts
I have just configured a mikrotik router in bridge mode and trying to apply firewall filter rules but its not working. Details of connectivity and config mentioned below:
Router’s Ethernet1 and ethernet 2 interface is running in bridge mode. Both interfaces have public IP. There is another interface ethernet 5 which is LAN interface and there are users connected with this interface to access internet. Ethernet 1 has Public IP address of (203.244.135.171/29) and There is a server connected to ethernet 2 with public IP address (203.244.135.172) which will be accessed by machine located at 83.225.98.42. My task is to allow LAN users to be able to browse internet only and drop everything else .Further server connected to ethernet 2 only accept requests from 83.225.98.42 and drops everything else. filter rule for LAN users is working but it is not working for server. Can anyone help me in resolving this issue.
Thanks & Regards
msusmani
Configuration.
MikroTik RouterOS 6.42.6 (c) 1999-2018 http://www.mikrotik.com/
[admin@MikroTik] > export
jul/30/2018 22:10:10 by RouterOS 6.42.6
software id = 6MP5-PTVK
model = RouterBOARD 750 r2
serial number = 63BD05F385CE
add name=bridge1_Internet
set [ find default-name=ether1 ] name=“ether1_WAN (Connected to ISP Router)”
set [ find default-name=ether2 ] name=“ether2 (Connected to Server )”
set [ find default-name=ether5 ] name=“ether5 (Desktop Users)”
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp_pool1 disabled=no interface=“ether5 (Desktop Users)” lease-time=3d10m name=dhcp1
add bridge=bridge1_Internet interface=“ether1_WAN (Connected to ISP Router)”
add bridge=bridge1_Internet interface=“ether2 (Connected to Server )”
/interface bridge settings
set use-ip-firewall=yes
add interface=“ether1_WAN (Connected to ISP Router)” list=WAN
add interface=“ether2 (Connected to Server )” list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=“ether5 (Desktop Users)” list=LAN
add address=203.244.135.171/29 interface=bridge1_Internet network=203.244.135.168
add address=192.168.10.1/24 interface=“ether5 (Desktop Users)” network=192.168.10.0
add address=192.168.10.0/24 gateway=192.168.10.1
set allow-remote-requests=yes servers=8.8.8.8
add action=accept chain=forward dst-port=80,443 out-interface=bridge1_Internet protocol=tcp src-address=192.168.10.0/29
add action=drop chain=forward out-interface=bridge1_Internet src-address=192.168.10.0/29
add action=accept chain=forward connection-state=established,related in-interface=“ether5 (Desktop Users)”
add action=accept chain=input in-interface=bridge1_Internet protocol=icmp src-address=83.225.98.42
add action=accept chain=input in-interface=bridge1_Internet protocol=tcp src-address=83.225.98.42
add action=drop chain=input in-interface=bridge1_Internet src-address=0.0.0.0/0
add action=masquerade chain=srcnat out-interface=bridge1_Internet
add distance=1 gateway=203.244.135.169
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=Asia/Dubai
/system routerboard settings
[admin
@Mikro
Tik] >
[admin@MikroTik] >
If you are using a bridge then the firewall won’t work from default. Why would a firewall filter a LAN bridge?
You need to go into Bridge > Settings and check “use IP firewall” to run the bridge traffic through your filters.
I have already enabled use IP firewall in bridge settings
I am able to block access of my router from WAN except an specific IP through this config but unable to block access to host connected to bridge interface. Can any one help?
try /interface bridge filter>
