Hi Dear Friend
When Active ip Flow on any version
My PPPOE Clinets connect To my mikroitk Router Very Slowly
So when Disable Ip flow is ok
How solve this problem
Thx
Hi Dear Friend
Thx
What is the CPU usage of the PPPoE server with users connected and the IP flow exporter running? Does the exported data take the same data path as the PPPoE clients therefore potentially causing contention?
My cpu usage is 17 percent
The PPPOE servers and IP Flow on deffirent vlans
How set traffic flow for PPPOe interfaces only :note this is dynamic interfaces
can i use not interface in traffic flow???
Any response to my problem ???
