remusd
April 28, 2022, 3:02pm
1
I have an hAP lite an I want to set it as an wireless AP for 2 networks. I am pugged in ether port 2 coming from a switch with 3 vlans: 10, 20 & 99. I have managed to make it work (2 wifi interfaces giving the correct ips), but I can’t manage to put an management ip on ether2. Here is my configuration:
# mar/08/1970 19:45:02 by RouterOS 6.45.9
# software id = 1GQP-YJB5
# model = RB941-2nD
# serial number = D1130DD62216
add admin-mac=08:55:31:17:2D:21 auto-mac=no comment=defconf name=bridge
add fast-forward=no name=vlan_bridge vlan-filtering=yes
/interface vlan
add interface=vlan_bridge name=VLAN99 vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=no_country_set disabled=no distance=indoors frequency=auto \
hide-ssid=yes installation=indoor mode=ap-bridge name=multimedia_ap \
security-profile=multimedia_sec ssid=multimedia vlan-id=10 \
wireless-protocol=802.11
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=\
0A:55:31:17:2D:25 master-interface=multimedia_ap multicast-buffering=\
disabled name=bce_ap security-profile=bce_sec ssid=bce vlan-id=20 \
wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add bridge=bridge comment=defconf interface=pwr-line1
add bridge=vlan_bridge ingress-filtering=yes interface=ether2
add bridge=vlan_bridge interface=multimedia_ap pvid=10
add bridge=vlan_bridge interface=bce_ap pvid=20
/interface bridge vlan
add bridge=vlan_bridge tagged=ether2 untagged=multimedia_ap vlan-ids=10
add bridge=vlan_bridge tagged=ether2 untagged=bce_ap vlan-ids=20
add bridge=vlan_bridge tagged=ether2,vlan_bridge vlan-ids=99
192.168.88.0
add address=10.0.99.6/24 interface=VLAN99 network=10.0.99.0
Any suggestions? I have tried following this tutorial (https://wiki.mikrotik.com/wiki/Manual:Bridge_VLAN_Table ), but It’s not exactly what I am trying to achieve. I want ether2, my trunk port, to also be the management port.
My suggestion is: never put v7 inside, but update to at least 6.48.6 long-term
before you do anything.
anav
April 28, 2022, 4:00pm
3
Check out this link…
https://forum.mikrotik.com/viewtopic.php?t=182276
You only should have one bridge (only need one bridge).
The hap is only acting as an AP/switch you dont need interface WAN, LAN but you should have Management interface!
Dont assign vlans in wireless configuration, that is for wireless configuration not vlans LOL it can be done, but keep it simple.
Vlans belong on /interface bridge port settings (and only by pvid if required) and /interface bridge vlan settings (which ports are tagged and untagged).
Why do you have a bridge giving out DHCP… be consistent, its an AP/switch NOT NOT can I repeat NOT a router !!!
anav
April 28, 2022, 4:17pm
4
Suggest you take ether3 and ether4 FIRST and create an off bridge access to do all the configuring!!
https://forum.mikrotik.com/viewtopic.php?t=181718
/interface vlan
add interface=vlan_bridge name=VLAN99 vlan-id=99 { correct only have to identify the management vlan)
add name=Manage
/interface list members
add interface=VLAN99 list=Manage
/interface wireless
disabled name=bce_ap security-profile=bce_sec ssid=bce \
add bridge=vlan_bridge interface=ether2 ingress-filtering=yes frame-types=admit-only-vlan-tagged { trunk port from switch }
add bridge=vlan_bridge interface=multimedia_ap pvid=10 ingress-filtering=yes frame-types=admit-priority-and-untagged
add bridge=vlan_bridge interface=bce_ap pvid=20 ingress-filtering=yes frame-types=admit-priority-and-untagged
set allow-remote-requests=yes servers=10.0.99.1
set discover-interface-list=Manage
/tool mac-server mac-winbox
set allowed-interface-list=Manage
add disabled=no dst-address=0.0.0.0/0 gateway=10.0.99.1
