http://wiki.mikrotik.com/wiki/IP_Pool_Statistics
Where do you get those statistics?
I do not understand your question…
Hello my friend,
Should I modify that script?
According to my settings?
Depending on the IP ranges a have?
I think yes because the script are not specific about one interval, but read directly the interval already defined…
I don’t no where i must edit
I have a ip-pool 192.168.1.1/24
Can you help me with this?
Thanks for the reply
YOU DO NOT NEED TO EDIT ANY!!!
SIMPLY PASTE THE SCRIPT ON CLI terminal (I just try and is compatible with RouterOS 6.7+)
This are output on my case:
IP Pool Statistics
SERVIZIO [0/99] 0 % used
RITARDO [0/96] 0 % used
MOROSO [3/96] 3 % used
SOSPESO [0/96] 0 % used
SCADUTO [0/96] 0 % used
CONTRATTO [1/96] 1 % used
TRAFFICO-ESAURITO [0/96] 0 % used
TEMPO-ESAURITO [0/96] 0 % used
GENERICO-1 [0/96] 0 % used
GENERICO-2 [0/96] 0 % used
BASE 640K U [0/150] 0 % used
BASE 640K [28/150] 18 % used
BASE 640K D [2/150] 1 % used
PRIVATI 1M U [0/150] 0 % used
PRIVATI 1M S [0/150] 0 % used
PRIVATI 1M [76/99] 76 % used
PRIVATI 1M D [9/150] 6 % used
PRIVATI 2M U [0/150] 0 % used
PRIVATI 2M S [0/150] 0 % used
PRIVATI 2M D [5/150] 3 % used
PRIVATI 4M D [5/150] 3 % used
PRIVATI 4M S [0/150] 0 % used
PRIVATI 4M [11/14] 78 % used
PRIVATI 4M U [0/150] 0 % used
AZIENDE 1M S [0/150] 0 % used
AZIENDE 1M [0/2] 0 % used
AZIENDE 2M S [0/150] 0 % used
AZIENDE 2M [1/2] 50 % used
AZIENDE 4M S [0/150] 0 % used
AZIENDE 4M [3/4] 75 % used
*** [0/99] 0 % used
it is also coloured and continue…
